Can you use any 20amp 3 pin relay?
pjoll84
6:47 AM
Victoria, BC Canada
Hey!
Can you use a universal/generoc 20 amp three pin relay to replace the horn relay? Provided you connect to the right pins?
Why would you want to get rid of that big ugly horn relay ?!?
Actually, you need a 4-pin relay. One pin is ground, the other is your low amperage trigger and the other two are high amp in and out.
