LIFTER assembly question
Mopewbie
12:11 PM
Ash Vale, Surrey, UK
Hi all, I thought my engine had a tapping sound and decided to give a go on the lifters.
I removed all them, opened, cleaned, reassembled and submerged in oil and force it up and down to load it.
Put it back and sounded louder. Improved by the time I was driving but I don't think it made any difference in the end.
ANYWAY... questions are:
1- I put the plunger oil hole OPPOSITE to the body oil hole. Is that wrong? Should they be on the same side? Makes no difference?
2- When putting the lifters in the engine do I have to try to keep the oil hole in a specific position? (up, down)? I thing they rotate in there but...
Thanks.
Are any of the lifters damaged on the end that rides on the cam?
You should never pump the tappets up before installing. It can cause retainer to seal/guide collison or even valve to piston collision.
Really? Just put them back empty then? I did that once and the noise was insane until they all gilled up.
It was quite pleasant thought.
That's the same thing I did. Did replacing the lifters take care of the tapping noise?
I just cleaned them and put it back. Noise still there but using a stethoscope the engine sounds very quiet. I'm beting on exhaust gaskets now.
