Aluminum radiator
Loulang
12:01 PM
Michigan
Anyone have any leads on we’re to get a 3 row aluminum radiator that will drop right in and use my factory shroud? Thanks in advance
I bought one from Auto City Classic off eBay and it’s been perfect. Went right in no issues. Didn’t realize how poorly my old one was working until I dropped that thing in.
All the ones I see on eBay have a 18 1/2 inch core mine is 17 1/2 and all the ones on eBay are 24 5/8 inch tall and mine is only 23 1/2 at the most. I put some thing on my radiator cap that was 1 inch and tried to close my hood and it won’t
While not Aluminum these seem to fit very well with the stock shroud.
Brand:
Summit Racing
Manufacturer's Part Number:
SUM-382026
Part Type:
Radiators
Product Line:
Summit Racing™ Classic OEM Radiators
Summit Racing Part Number:
SUM-382026
UPC:
190861063754
Radiator Material:
Copper/Brass
Radiator Style:
Downflow
Transmission Cooler:
Yes
Inlet Location:
Upper passenger side
Outlet Location:
Lower driver side
Overall Width (in.):
28.00 in.
Overall Height (in.):
23.25 in.
Overall Thickness (in.):
3.50
Row Quantity:
3
Radiator Finish:
Black
Core Width (in.):
25.00 in.
Core Height (in.):
17.50 in.
Core Thickness (in.):
2.00 in.
Radiator Inlet Size:
1.500 in.
Radiator Outlet Size:
1.750 in.
Trans Cooler Adapter Fittings Included:
No
Tube Size:
1/2 in.
Fan Included:
No
Radiator Cap Included:
No
Quantity:
Sold individually.
These pics are from my parts car radiator but same dimensions
The one he posted looks like the first one I posted. But the one you posted Don is cheaper and looks identical. Installed one like it in the roadrunner.
Just found this one also lol been looking all weekend when I had a min
My Cold Case fit pretty good after I "adjusted" the mounting holes. Had to fabricate some brackets to adapt the shroud... for me it wasn't a big deal but as far as this being a direct bolt in, not so much. They sell a shroud for this rad but the factory one works just fine.
That Does look nice but my fan shroud on a 66 wont attach to that
This is what I used on my 66 link Not sure about mounting your shroud because I bought their shroud and fan combo. Think I had to drill a couple of mounting holes om one side. Scroll down for the 3 row.
I have looked at the champion radiators and the ones that will except my fan shroud are a inch taller than mine and won’t fit I thought about getting it with their vans but I do not have a spot for their sensor seeing how I have the holly sniper and my dash and a mechanical gauge already installed. I have the mechanical gauge because I have not got my gauges re-done it yet and the holly sniper is not accurate. So I do not trust my dash or the holly sniper
The sniper should be accurate?
What does it show?
I have the Sniper PDM so hooking the fan up was no problem. I also bought the Standard Motor Products TX3 CTS and it's supposed to be much more accurate than the Holley one.
I almost wondered if I switched the sniper sensor and my mechanical would it read different? Is there a wall between the 2?
Do you have a part number and have you tried it yet?
