- 4:51 AM
- Apr 13, 2012
- Granite Bay CA
One of the stark differences in older cars and newer ones is the amount of noise that is heard while driving at freeway speeds.
I can go for a ride in a newer Challenger and feel somewhat isolated from the outside world.
The same road and duration in my '70 Charger and I feel overstimulated, almost like you feel after leaving a live musical event.
It isn't all bad but I wonder what can be done to take the edge off just a bit.
Several factors add to the noise so I think that there are areas to address to limit some of the noises that we don't want. For me, part of the problem is that due to some hearing deficiencies, I may have a hard time identifying what is causing the noise that I want to scale back.
I don't want a silent car. Hell no......
I just want to scale it back a little. I just need help finding out what is responsible for the noise that bothers me the most.
First off, I have NO drone. This car has somehow never had a problem with overheating or exhaust drone noise. Somehow, I dodged those two bullets.
Secondly, I have tires that are sticky and wide. 100 treadwear tires do not last long and are not great for wet weather.
How much of the noise that we have is from the wind itself? Looking at new cars, you see hidden rain gutters, flush bumpers, wheels pushed to the edges of the body and mirrors with rounded or pointy shaped sections facing forward. For contrast, look at this:
Starting from the rear, you have a bumper that has a noticeable gap from the body where air can get disturbed when flowing by.
Moving forward, there is the rear wheel opening that has a gap between the tire and body. Above that there is the quarter window taper which has a bit of a pocket in it at the bottom. The side view mirror is almost flat at the front side. Above that, the A pillar has the start of the rain gutter and the wing window. The windshield wipers certainly grab the air along with the front wheel openings but how about the huge sugar scoop grille?
Looking at a late model, you can see a lot of differences if you look close.
As you might expect, the recessed grille is a step backward for aerodynamics but was deemed necessary to get the styling right for this car. Still, look at the gentle shape of the front bumper, not how the tires are out to the edges. The windshield wipers are tucked down and out of the air flow. The mirrors have no flat or blunt faces either.
Part of what attracts me to the classic cars is the styling. I'm sure that you feel the same way. Because of this, we are limited as to what we can do in terms of styling changes to reduce the noise. I do have my tires out wide but not for aero...It is because I loved the NASCAR look:
I need windshield wipers. I love the way the grille looks. I may change to the late 1970 style racing mirrors though that alone will result in almost no noise reduction.
What else can be done to reduce noise?
In 2012, I did add a fair amount of "Rattle Trap" matting.
The late models have flush mounted windshields. This can be replicated but now I'm looking at a custom windshield or shrinking the stock opening and fitting the stock windshield, both options are not cheap.
Flush door handles? Hmm...Hard to do without going custom....plus, I like the stock design.
