I have added a short demonstration video to the original post for those who may remain skeptical that the load placement matters for the all stock original Chrysler charging system.
Excellent addition to your first expose....detailed yet concise with explanations....great learning tool for the uneducated and the self proclaimed "experts" who have no clue as to what actually happens. Thanks for the update AND effort....!!!!I have added a short demonstration video to the original post for those who may remain skeptical that the load placement matters for the all stock original Chrysler charging system.
Nice explanation. Many will not grasp.I have added a short demonstration video to the original post for those who may remain skeptical that the load placement matters for the all stock original Chrysler charging system.
There have been some recent threads here where the subject of connecting loads at the battery on unmodified stock factory charging systems has come up. As an old-time Chrysler dealer/factory trained master tech, with that specific dealer experience back then and the many years spent designing and installing aftermarket 12-volt DC power/charging systems professionally for high-end automotive and marine applications, leaves me perplexed frankly about some of the responses from some otherwise seasoned appearing members here. Its clear some just can’t separate this stock factory charging system, in its original form, from every other 12-volt automotive charging system in general. The attempts at written descriptions and diagraming to differentiate this system appears to have fallen on some deaf ears, or blind eyes in this case.
For those that are interested in a fact-based video presentation on this subject, specific to the original Chrysler factory charging system design and touching a bit on ammeters/melted bulkhead connectors, I submit this video, forgive the amateur production quality. Feel free to critique the info presented but stay on subject of the as original Chrysler charging systems from this time period please.
For those who can’t separate this charging system from every other vehicle on the road, are convinced an ammeter-based charging system is a "ticking time bomb" while placing loads where ever, or already understand the negative impact of adding loads to the battery on the as original Chrysler ammeter-based charging system, don’t waste your time (about 28 minutes start to finish) watching this video, you'll never get the time back.
Disclaimer, once more, this information does not apply to any modified, ammeter by-passed, volt-meter converted, engine compartment main charge circuit by-passed Chrysler charging system, or every other charging system configuration on the planet not running a battery ammeter. Load placement does not matter for most other systems.
Adding in links to the slides used in the video.
Slide 1
Slide 2
Slide 3
Slide 4
Slide 5
Slide 6
In previous discussions (or arguments) about all thing’s ammeters, I have always attempted to bring up load misplacement as the leading cause of most ammeter connection related issues a lot of folks like to blame on the factory ammeter, always has been. As I said, this post was intended only address the notion that you can load this system any way you want without any consequences, that the original charging system components will not be impacted and to say otherwise is “nonsense”. That if this overloading results in heat damage to the ammeter and related connections/circuits, then it was a poor design and should be removed from every remaining Chrysler product from the time. That if you don’t “get rid of” that factory ammeter it will eventually burn down your car for no other reason whatsoever.From what I have seen in the past the argument is not which side to put a load or how to connect a load (accessories), it has been whether retaining the ammeter and stock wiring was worth the potential risk. This explanation and associated video pretty much reinforce the stance of not having this arrangement or at a minimum altering the stock arrangement.
If you are to connect all of your desired accessories on the alternator side then you need to make concessions for that, namely some type of terminal. Why even mess with this situation for the sake of having an ammeter. I understand that an ammeter can provide information that an volt meter cannot but I would contend that the risk as well as the associated requirements to make it work well are not worth it; in other words "the juice is not worth the squeeze" unless you have a bone stock car and you want that gauge to work.
I really appreciate the information contained in the thread, however it only serves to confirm to me that I have no need for a ammeter.
Your information and intent were not lost, I was merely point out that the main typical argument is concerning whether to keep the ammeter or not and/or what risk it may or may not present. I completely agree that in original or near original configuration a vintage Mopar has really no more risk of electrical failure than other types of systems.In previous discussions (or arguments) about all thing’s ammeters, I have always attempted to bring up load misplacement as the leading cause of most ammeter connection related issues a lot of folks like to blame on the factory ammeter, always has been. As I said, this post was intended only address the notion that you can load this system any way you want without any consequences, that the original charging system components will not be impacted and to say otherwise is “nonsense”. That if this overloading results in heat damage to the ammeter and related connections/circuits, then it was a poor design and should be removed from every remaining Chrysler product from the time. That if you don’t “get rid of” that factory ammeter it will eventually burn down your car for no other reason whatsoever.
Potential risk? There is potential risk created to any electrical system or components when being operated outside of its original current design limits or is poorly serviced/maintained. I’ve seen burned wires/connections on every kind of vehicle over the years, as a direct result of overloading beyond given circuit design limits and/or terminal/connection abuse. Fact remains, even today, any serious real time monitoring of batteries or DC circuits involves ammeters of some kind. If a voltmeter or an idiot light works for some to monitor the charge/no-charge status of your original charging system, great. If this info only reinforces your perception of risk, that’s fine too. I take issue with those who promote their anti-ammeter views without the full understanding of how this system was designed to function in the first place, or just because they read it in an article somewhere. Or an article that must make up some premise about an ammeter leaving some car on the side of the road, then pictures a pristine ammeter with no heat or connection damage whatsoever to back-up their claim.
Said it before, a great many Chrysler products were built with this system, the vast majority of them lived and went to their wrecking yard gave without sulfuring the dreaded “ammeter meltdown syndrome”, many survive today, all without anyone screwing around with loading at the battery or connection abuse and operated fully within its original design limits.
Your signature references several modified vehicles, I assume electrical modifications as well, once more the subject of this thread was about as originally designed. There are some modifications where the original ammeter is not suited or supported, the Dakota Digital cluster as an example. If all someone takes away from this is that this charging system as originally designed will not support their modification plans or reinforces some perceived risk factor, I’m ok that too.
Length is unimportant as that fuse-able wire is going to burn at the same load to matter the length. 6 inches should be fine.My 12ga fusible link came in a 4ft roll, how long should I cut the link to? I saw someone on our sister site (A Bodies) mentioned 6” long but this is way too important for the survival of my car to guess.
FYI.....Fusable wire information.....Length is unimportant as that fuse-able wire is going to burn at the same load to matter the length. 6 inches should be fine.
I agree for this application, 5-6” is sufficient. I would consider 6” as a maximum however, excess fusible link length will contribute to unnecessary voltage drop across the link in this circuit.My 12ga fusible link came in a 4ft roll, how long should I cut the link to? I saw someone on our sister site (A Bodies) mentioned 6” long but this is way too important for the survival of my car to guess.
Slide 1
Slide 2
Slide 3
Slide 4
Slide 5H
Slide 6
By far the weakest link in the original all stock charging system is the routing of charging/load current through Packard terminals in the bulkhead connector. They were/are under current rated for the real-world stock current loads on that circuit. Mis-placed added loads at the battery only increased the current load on the terminals. These terminals have been heating up and failing at high rates since these cars were new, especially with high optioned cars. For as you describe all stock loads, at a minimum, I would by-pass the bulkhead charge system Packard terminals, number 18 & 16. There is no electrical need for those disconnects at all. The M&H reproduction harnesses are nice accurate reproductions of the original wiring, the problem is this weakness is also reproduced accurately.Hello all just wondering I'm running a dead stock car no extra acc but it's a factory r/t se so its got a/c and power windows & rear demist do you think the car be fine with the standard ammeter set up or would it pay for me to run a direct wire through the bulkhead at minimum as I'm doing the full wiring at the moment with all new m&h harnesses.
So once i by pass the bulkhead terminals would i need a bigger amp alternator with the factory A/C,lights ,radio all running at once or would the standard alternator be sufficient.As those options would be on the correct side of the charging system.Also I'm wanting the car to look factory correct could i pass the straight run wires through the bulkhead plug so it looks standard i was thinking drilling the hole larger on the bulk head plug so the wire passes through cleanly ? also do i need a fusable wire going through the bulkhead or better to have a 50amp circuit breaker under the dash would that be okay ? sorry for the million questionsBy far the weakest link in the original all stock charging system is the routing of charging/load current through Packard terminals in the bulkhead connector. They were/are under current rated for the real-world stock current loads on that circuit. Mis-placed added loads at the battery only increased the current load on the terminals. These terminals have been heating up and failing at high rates since these cars were new, especially with high optioned cars. For as you describe all stock loads, at a minimum, I would by-pass the bulkhead charge system Packard terminals, number 18 & 16. There is no electrical need for those disconnects at all. The M&H reproduction harnesses are nice accurate reproductions of the original wiring, the problem is this weakness is also reproduced accurately.
