Nacho-RT74
This guy definitely doesn’t know to read…
Whatever… won’t play this game anymore. Exhausting.
							That's beyond my skill set lol I'm assuming you mean the fusible link that I have going from the starter solenoid and into the bulkhead. I can figure out which wire comes off the interior side, but if I get rid of it then I don't know how to get power to the gauge cluster.
Unless I'm just running my own, dedicated link/wire to the gauge cluster from the solenoid, and "going around the bulkhead", so to speak. Meaning I would cut the wire coming in, at the bulkhead/interior side, then connect the wire I have going to the ammeter now (I just wired that part up tonight) and, instead, connect it into the wire I just cut, leading to the gauge cluster.
So, I am then by passing the power going into the bulkhead fitting instead of running a parallel circuit.
I can figure that out, but then I don't know which wire to bypass coming back through the bulkhead
This is what I'm saying lol information is all over this forum and others. None of it's consolidated. It makes finding updated and proper information very difficult.
Before I run my wire from the ammeter back through the firewall and to the alternator, I will see if I can figure out the other wire going through the bulkhead from interior back into the engine compartment. If I can, I will get rid of those on either side and run my own wires.
Luckily, my gauge cluster's still out, so easy to make changes.
Thank you for the advice. I'll see if I can figure out how to do it.
You leave the stock black 12ga ammeter to splice 1 wire connected to the ammeter as original, this powers all the factory loads you seemed concerned with. As mentioned, only one run (one fusible link) from the battery to the ammeter, preferably not though the bulkhead disconnects.I hate to do this, but yes: another clarification post about all of this LOL. I've been reading multiple threads and links for about two weeks now. The info is scattered and some is written in a way that is tough to understand because some of the wordage used (english as a second language, etc). So, here I am.
I want to take some of the load off the bulkhead so it LOOKS like I want to:
1. Run a 10g wire, with 14g fusible link, from the starter relay, through a grommet in the fire wall, to the "battery" side of the ammeter.
2. Run an 8g wire from the "alternator" side of the ammeter, back through the grommet, then to the alternator pole.
This will take a lot of the load off the bulkhead, making it safter to operate with far less risk for overheating.
Does this sum it up? I'm looking to add wiring because I like having the ammeter as a reference point, along with the voltage display for the Sniper unit. I just don't want to melt stuff.
I assume bypassing the bulkhead would be even better, but I don't know how I'd get power to the gauge cluster otherwise, so I'll be happy with just taking some of the stress from it.
The picture, posted by a fellow member, that I'm using for reference:
For the longest time I had thought that was the way the factory did it. When I got my road runner in 1977, it was already direct wired to the ammeter and I didn't know it was a mod.Back in the day I was tired of the ammeter connector overheating. I drilled through the cavity and spliced a wire in. The connector is just to provide a convenient point to assemble on the line and disconnect for repairs. I bet your bulkhead is half melted along with the connectors corroded black. Not the correct way to repair or restore, but it works, is safer than short circuits, and is more fun than popping the hood to wiggle the harness to get the damn ol' Mopar started.
Do not double up on the fusible link.
Another approach, upsized wiring, full bulkhead by-pass, "The Fleet By-pass".
Here’s the logic, fusible links, or any circuit protection devices, of the same value connected in parallel as described will have a protection value close to twice as high as the original intended value. Will allow twice as much current to flow before either one opens if a short should occur at the ammeter or any where else in the un-fused portion of the factory charge/power circuit. Never parallel fuse or any circuit protection devices.I've seen some suggestions eliminating dual fusible links (only running one) Don't see the logic in that. Fuses and fusible links are there to carry current and protect when over current conditions occur. Why would anyone do away with that protection.
I kinda have mine like that now. The exception is that the stock black and red wires are still connected to the ammeter. They still go through the bulkhead, but the OEM wire going from the starter relay to through the bulkhead is also a fusible link.
1. I understand that it's better to disconnect the OEM fusible link wire from the the starter solenoid, find where the wire continues into the interior via the bulkhead, and then cut it from wherever it splices into the interior harness. This avoids using the bulkhead for power from the starter relay. Then I take MY fusible link/8g wire and run it from the starter solenoid, though a grommet, then splice it where I cut the OEM wire that goes to the interior harness.
I can't find anyone to tell me I'm right there, but it makes sense.
2. Where I'm stuck is that I don't know which wire comes from the alternator through the bulkhead so that I can cut THAT wire from the interior harness, then splice MY 8g wire from there, though the grommet, then to the alternator.
Is it literally the one circled in green so that I can just look at the bulkhead and find the wire indicated? If so, that's super easy, I've just never had anyone actually say it.
I want to reiterate: I know VERY LITTLE about electrical, so learning this as I go. These diagrams make perfect sense in theory, I just don't know where all the wires are on the car.
If I can figure it all out, I'd be more than happy to make a "Dummy's Guide to the Fleet Bypass" or whatever so you guys don't have to spell it out to any more dummies. LOL
Thanks, again, for everyone who keeps replying to these threads, over and over. I do understand the theory and reasoning, just want to be sure I'm bypassing the right wires.
OOOOOOR you can also make this looping into the ammeter the wire originally running to the bulkhead into the cab
I made this sugestion sending the diagram on a private message with a member from dodgecharger.com and he added pics of their final job for his own car (69)
The 8 gauge wire he used up to the ammeter is becoming on dual 12 gauge wires up to the main splice. Pretty much what I want to mean when keeping the existant 12 gauge one from alt if still in working order, and being 10 gauge pretty much enough on the parallel path.
If you believe the dual fusible link theory then the diagram Nacho posted supplying the high load fan direct off the upgraded alternator source is by far the better choice.Unless I'm missing something, that's what I have now. I have the factory wiring in place because it works, but since I added the Sniper 2, I wanted to take stress off the bulkhead so...
I now have an additional fusible link from the starter solenoid (sounds like I need to get rid of it, since the OEM feed has one) into a 10g wire that goes through a grommet, directly to the ammeter.
I also have a 10g wire, no fusible link, going from the alternator, through the same grommet, to the other side of the ammeter.
That is what the picture you posted shows, yes?
I'd still add an inline fuse for the fan circuit. The way your diagram is now; there is absolutely no protection until power is pulled through the fuse panel. Way too many opportunities to smoke those wires!
It's not on you diagram. Look up a few posts to the one Nacho posted. Most electric fans are real power hungry so by switching that load to the alternator output and adding the inline protection fuse you should see a considerable drop in what appears to be a charging rate but is actually fan power feed causing the ammeter faults reading.Gotcha. Which is the "fan circuit"? I don't seem that on my picture.
If you are curious of the outcome, try a temporary hook up to satisfy your mind.
