1967 Dodge Charger 14" Tire Size
Charger Too
11:08 AM
Illinois
What is the correct radial tire size for a 1967 Dodge Charger with 14" rims? Thanks!
Radials were not on that car when new. What you would do is, interpolate the factory size to the corresponding size radials. Example: F7014 would be P215-70R14.
I agree. My new 1969 SuperBee came with F70x14 tires. So 215-70R14 would be closest size replacement. I think the 1967 Charger originally had 7.75x14 tires, same as my '67 R/T.
My 66 charger had G78-14s in old school tire size I think that breaks down to 215/75R14 in new school tire sizing.
Hmmm. It seems like I'm always rowing against the current.
I guess it depends on which "original" dimension you want to hold, as you cannot match the original tire dimensions with a P series tire, I think.
For me, the most important dimension on that big ol Charger is the tire diameter. A 7.75-14 was over 27" tall. BFG used to make a P235-70-14 TA that I thought looked well balanced. I think it was just short of 27". I think a 215 is less than 26"
Last time I went to buy tires, BFG no longer made the 235-70-14. Because of that, I stepped up to a 15"
Pics of my Charger with 235-70-14
For me, the most important dimension on that big ol Charger is the tire diameter. a 7.75-14 was over 27" tall. BFG used to make a P235-70-14 TA that I thought looked well balanced. I think it was just short of 27". I think a 215 is less than 26"
Pics of my 235-70-14
Very nice Charger. I have not very often seen those "Mag-look" wheel discs on a Charger, given that they already had a special disc. I know they were an option, and my 1967 R/T came with a full set of them in the trunk. My R/T was a 20-year-old car when I bought it. The original engine and transmission were gone, but the wheel discs survived!
Thanks.
Yes, it was an opton. "Deluxe" wheel covers. $21.30
When I stepped up to the 15s, I went to Magnum 500s too. I think it looks good w/ the Magnums, but I miss the hub caps, and they enhanced the sleeper look, IMO. As pictured, the car ran 11.70s at 120.
I think there is a way 14" hub caps can be made to work on 15" rims. I might do that some day.
225/70-14 are probably best for the stock 5-1/2" rim
I just bought a set of 215.75.14 radials for my 1966.
Going whitewall for the ultimate sleeper look. Just to change it once in a while
Originally was a 7.75-14 blue stripe sidewall.
Blue stripes are unique, and available..... but a friggin FORTUNE!
(775x14 bluestripe from Coker, $481 each)
Cooper still has Cobras available in 225 70 14.
That is what I would probably run..... if I just HAD to keep 14s
99% chance I'd put 15s or 17s on it.
Even though that's what my car SHOULD have.
I have zero interest in a set
Only to clash in a big way with the red interior
What color is your car? It looks like Copper, like my 1967. What color is your interior?
