Orig69
- 1:36 AM
- May 16, 2021
- Toronto Ontario Canada
Could you feel a performance improvement from the jet change on the SD carb?
			as it involves laying on my back and looking up, which will likely trigger my vertigo
Run out of gorilla tape?I did a nut and bolt check on the car today. I found a couple of loose exhaust hangers and a loose fan belt. I noticed a loose trunk hinge bolt at the last car show, but when I went to tighten it the inside nut was seized and everything just spun. I cobbled up a tapered shim out of a washer and pounded it in with a drift punch. Problem solved, I think.
I'm with you - stuff fills up fast!I painted the trunk hinge repair and loaded the trunk for the trip. Just need to pack my suitcase.
What Dynomax part number? They should be offset on one side, center on the other. 17747 maybe?
Repro Hemi mufflers are smashed in on opposite corners to clear driveshaft and springs on B-bodies.
