Belsinor
No I have a flamethrower 1.5ohm coil. I'll try .035 and see if that worksAre you running a stock ignition coil? The stock gap is .035” and a stock coil might not fire at all at .040” (ask me how I know)
I do not know for sure, when I bought the car I was told it was hydraulic but I confirmed with a scope that they are rollers. I have not done a compression test yet, but since they were firing when warm that was not high on my list to do. I'm trying to answer what I know and making a list of what to check next time I'm working on the car.So you do not know if you have solid or hydraulic? Have you done a compression or leak down test? You ask for help but chose what questions to answer. I just do not get it.
Sometimes engines are like women......you need to take the time to warm them up a little b4 using......????Yes, how do you know they’re not firing? What is your spark plug gap?
I have NGK #5 right now, going to try closing the gap to .035 and see if that helpsRead post #13!
I think I have an idea how you know, lol. Closing the gap to .035 brought 1 and 3 to life, if I bypass the resistor all 8 fire nowAre you running a stock ignition coil? The stock gap is .035” and a stock coil might not fire at all at .040” (ask me how I know)
Excellent! I tried to gap .040” on a stock coil and my car wouldn’t fire. Maybe your coil is about to go out?I think I have an idea how you know, lol. Closing the gap to .035 brought 1 and 3 to life, if I bypass the resistor all 8 fire now
Neither does any of the "wonder coils" that are said to provide 50+ blazing horsepower increases. 001" differrnce in plug gap make no difference . Try different gap configurations....side gap, j-gap, multi ground, surface gap. Try different brands.....besides what the narrow thinking NGK boys recommend.....you might be surprised. In my GTX, I use Champion HO-8A a platinum electrode non projected center electrode plugs origionally made for Homelite 2 cycle racing go cart engines running methanol and nitro methane mix plus castor oil......experiment a little.....A larger plug gap does nothing for power.
The Champion HO-8A (or alternately Champion UJ-11G) has a very broad heat range tolerance that resists low temp/low speed fouling (booster gap design) yet is immune to high speed/rpm pre-ignition conditions and due to the small diameter platinum center electrode resistant to mis fire and J-gap to allow better flame propagation. Name the NGK equivalent and I'll try them. Thus endith the lesson in proper spark plug selection........and put your preconceptions and hearsay knowledge in the round file.......And Bob, for us narrow thinking NGK 'boys', what does a Champion HO-8A do that any any other brand with similar electrodes would do? You left that bit out....
