TorRed
- 7:34 AM
- Dec 12, 2023
- The Villages, Florida
Hi All, I have been waiting to rebuild my 70 Roadrunner for so long I've now decided to keep it 'mostly' stock, at least as far as keeping the original 383 engine, 727 trans and 8.75 rear goes. I've already spent some serious money on performance parts, many I'll likely not use now (can you say lots of FBBO For Sale listings?). I would like to use my Lunati hydraulic roller cam if I can, with forged ICON domed pistons 9.6 compression with stock heads, stock HP exhaust manifolds, and TTI 2.5" H-pipe exhaust pipes. I'd like to push the HP & TQ numbers to 400 or a little better. I'll probably run an original DP4B intake like I did back in the day with a 750-800 cfm Carter or Edelbrock carburetor. First can I still run this cam:
20230712 Lunati Voodoo Retro Fit 3 Bolt Hydraulic Roller Camshaft BB Chrysler
Lunati's Voodoo Series deliver more area under the curve than any other series. This means more throttle response, quicker acceleration, more vacuum, and better efficiency. These factors, combined with max hp and torque, make Voodoo cams the best choice for a wide range of high-performance applications
This 1958+ Big Block Chrysler V8 361-440 is designed as a high performance street cam. Likes upgraded intake, carb, and exhaust. Needs 2800 RPM stall converter in most cases. Requires 9.5:1 compression for maximum performance
SPECIFICATIONS
Vehicle Make BB Chrysler, Chrysler
Camshaft Type Hydraulic Roller
RPM Range 2200 to 6200
Intake Lift 0.535
Exhaust Lift 0.550
Intake Duration at 50 231
Exhaust Duration at 50 239
Advertised Intake Duration 282
Advertised Exhaust Duration 290
Camshaft Series Voodoo
Valve Setting Hydraulic
Lobe Separation Angle 110
I've looked at a lot of stock stroke & similarly upgraded intakes and compression ratio builds online, and these specs aren't that far off from what I see others using. The Mopar 484 cam is very close, but has a 108 LSA vs my 110, and my cam has more lift and a little more duration. I'd like to stay with a hydraulic roller cam mostly for the oil issues / limitations. Thoughts?
Another area I'd like to tweak are the heads, definitely going to get them gone over with hardened valve seats but could use advice from others about what else to do to the heads? Port matching, bowl blending, bigger valves?
Finally. I have a tight 3000 stall convertor and 4.10 gears for the rear. I also have a Gear Vendors .78 overdrive that I was planning on using, but if the motor makes all it's power down low may go with 3.23 or 3.55 rear gears and possibly sell the overdrive.
Number one goal right now is to build a 'bullet proof' motor that's fun to drive, sometimes fast, but doesn't risk the stock driveline that's been in the car for 54 years.
I'm sure I'll have more questions, but would really appreciate advice from those who've done similar builds especially including what to do's and what not to do's.
Thanks in advance, Jim
SPECIFICATIONS
Intake Lift 0.535
Exhaust Lift 0.550
