I hope your frames are good. Since your doing floors you can do some cutting to look.
			They are definitely NOT ok. Rusted and will need to be replaced - a peek below.I hope your frames are good. Since your doing floors you can do some cutting to look.
Did you find a broadcast sheet under the rear bench seat cushion? It will be squeezed between the springs and seat cushion.I didn't do much the first week except tag and bag all the parts scattered in the trunk and interior. The original Holley 4368 carburetor, base plate, etc were there, so I wanted to make notes and store them appropriately. Once the miscellaneous stuff was sorted, I removed the seats hoping to find the build sheet. While no build sheet was found, I did get the seats, sill plates, accelerator, armrest, and front seat belts removed and tagged. I broke off 6 of the 8 seat rail studs due to extreme rust. I searched the forum and found a couple of sources (currently out of stock) and suggestions to use carriage bolts instead. I'll watch the websites for stock as I have time before I'll need them. I took pictures of the seats to show the condition and extreme fading. They should be brown and will be again when I replace the leather/vinyl coverings. The rear seat is still in decent shape, but I'm guessing the threads, etc will eventually break if I try to avoid replacing that vinyl. There are many places where I can see the ground or the seat brackets underneath, but a good start (finally).
Unfortunately no. I've searched everywhere and the interior is mostly disassembled. There was lots of insulation, etc in the heater box with a few mouse skeletons. If there was one, it's long gone.Did you find a broadcast sheet under the rear bench seat cushion? It will be squeezed between the springs and seat cushion.
Did you check with the registry? They might have paperwork for your car VIN.Unfortunately no. I've searched everywhere and the interior is mostly disassembled. There was lots of insulation, etc in the heater box with a few mouse skeletons. If there was one, it's long gone.
Yep - checked with Don, didn't have anything for it... yet. It's not the end of the world. For as much as I know my brother found it 40+ years ago and threw it away.Did you check with the registry? They might have paperwork for your car VIN.
1970 Dodge Charger Registry
Don't I know it! Sitting around in a damp garage for 40+ years did it no favors. It let that NY salt eat away at it.The termites had fun on your car!![]()
It's been a busy month. I've removed the steering column and pedals finishing the interior disassembly. I moved to the rear and removed the bumper, tail lights, wiring, trim panel, etc. Yesterday, I finally dropped the rear axle and put the back end up on twirler brackets with casters. I have some organization/cleanup this week before moving to the front end.
Speaking of the front end, when I removed the steering column, I removed the starter shield and discovered the front frame rail is in two separate pieces separated by 12-18 inches of nothing. I won't touch the K-Frame or remove fenders until it's in the body shop and on a jig (I'll let them). The front twirler brackets were supposed to attach to the K-frame bolt areas, but I may adapt them to the bumper mounts to keep whatever rust is holding everything together in place. Should I consider making a brace to connect the 2 pieces of the front rail for transport to the body shop (a makeshift frame rail)? I'll take a closer look once I get the drivetrain removed in a couple more weeks.
Pictures of progress and rust.
View attachment 1713476View attachment 1713475View attachment 1713477View attachment 1713478View attachment 1713479
I have a couple rough estimates so far - but obviously neither has seen the car in person yet.Have you gotten any estimates on what all that metal replacement & body work will cost?
Paging @eldubb440
500-600 hours + any additional parts/paint (above the 10k of AMD already purchased).Any estimate on body shop costs?
