- 11:47 PM
- Apr 13, 2012
- Granite Bay CA
I have tinkered around with all sorts of things with these cars.
Even here in California, we deal with rust.
My welding skills are fair, depending on what I'm welding. The thicker the metal, the better my welds.
I have to smooth over every weld in sheet metal though. For me, it is always a moving target to have the welds hot enough to penetrate but not too hot where they burn through. In short, I have to grind everything to get it smooth.
Therein lies the point. I have used traditional grinder discs, flapper wheels and cutting discs to knock down welds. I'm always nervous about the areas around the welds getting ground thinner and having weak areas. I've seen welds addressed by some guys where it looks so good, you cannot see where the welds were. I know that is a testament to skill but I'm guessing that those guys are using better tools than I have.
What tools are those? What techniques do you use to make the seams invisible?
It is fair to guess that it starts with better welding. It is easier to clean up a good weld than to cut off popcorn welds.
