- 10:56 PM
- Apr 13, 2012
- Granite Bay CA
Tell me BOB, since you are compelled by what can be described as an obsession to follow me around on this forum only to criticize, when was the last time that you actually ever worked on a car?How hot is too hot is a rhetoric question.....it's similar to the question: how high is up or why is there air? WHY DOES IT MATTER? Perhaps this query should be posed to our resident "trivial expert", specialising in totally inconsequential and useless information, who, cannot resist comments on anything/everything.....like installing a limiter plate in a distributor, Lithium batteries (amps vs amps), tire valve stem cap torque, soldering aluminum, ...... Mr. If I don't comment, I'll explode......Kern Dog.......which he'll likely do an documented expose, complete with temperature vs resistance vs amps vs ambient temp......let's see how long it takes......
BOB RENTON
When have you done bodywork? When have you painted? Have you ever pulled a wrecked car from a yard and rebuilt the structure and got the car drivable again? Have you rebuilt an engine? How about suspension, brakes and steering? Have you installed an aftermarket A/C system? Have you welded quarter panels on, exhaust systems together, installed home-built frame connectors and torque boxes?
I'd love to read from your extensive history of restoring interiors by reskinning seats, installing headliners, carpets and seats.
I'm sure that you could regale us with your skills with aligning body panels, installing windshields, fitting bumpers and installing decals.
Please, share with us all the things that you have done.
Have you noticed that every time you write something to criticize me, the other members here seem to be on my side? Why do you think they do that?
I'm not forcing anyone to read what I write here. You are under no obligation to follow me around. It sure seems like you have KDDS.
Kern Dog Derangement Syndrome.
