2024 14th Annual FABO NHRA "Pick 'Em" Game - It's NITRO Burnin' Time Again!!!
Is this the retro paint scheme Ron Capps might use on his 2025 U.S. Nationals funny car?
Don Prudhomme kinda hinted at it during an interview yesterday...
The point reset protocol and special rules for the end-of-season 6-event "Countdown" was last posted during the 2022 "Pick 'Em" game. So, for both new NHRA "Pick 'Em" game players and those who forgot, here they are:
PLEASE NOTE SPECIAL "COUNTDOWN" GAME RULES (effective following the U.S. Nationals):
* The "pick carry over" is not in effect for the end-of-season 6-event "Countdown". You MUST either post picks for each event or "lock" your picks if you feel you may forget to post new event picks or you want to guard against your computer going down for any reason. Of course, you can always override your "locked" picks for any event or change your "locked" picks at any time.
* If your picks are currently "locked" then they will continue to be "locked". If your picks are not "locked" or they are "carry over" picks from previous events, then you MUST post picks for the next event and each following event in order to stay in the "Countdown" for the remainder of the 2024 NHRA season. Of course, you can post new picks for the first event of the "Countdown" and "lock" them.
* If you override your "locked" picks for a single event, your picks will revert back to the "locked" picks for the next event unless you post otherwise
* Following the completion of the U.S. Nationals I WILL NOT BE SENDING ANY REMINDERS TO POST PICKS FOR THE REMAINDER OF THE 2024 NHRA SEASON. To use a classic drag racing saying, "If you snooze, you lose"!
*If your picks are not "locked" and you fail to post picks for any event during the "Countdown", then you will be "parked" for the rest of the 2022 NHRA season with the points you have earned up to that time.
Here's how the game points will be re-set following the completion of the U.S. Nationals:
2000.0 - "Pick 'Em" game point leader after the U.S. Nationals
1970.0 - second place player unless the point separation from the first place position is less than 30 points. If you are only separated from the first place player by less than 30.0 points, then you will maintain that lower-than-30.0 point separation.
All player positions below the second place score will be separated by 10.0 points unless a player is less than 10 points from the player in the position in front of them. If you are only separated from the player immediately in front of you by less than 10.0 points, then you will maintain that lower-than-10.0 point separation.
Example:
In the 2019 game, '64BEL' (FBBO) was only 4.5 points behind the player in front of him so he started the "Countdown" separated by only 4.5 points.
In 2019, before the point reset, the difference from 1st to 17th was 1044.5 points. Following the point reset, the difference was only 171.0 points.
By the way, the 30-point lead at the beginning of the "Countdown" is not insurmountable. In the 2019 game, the game leader following the U.S. Nationals had a 30.0 point lead at the beginning of the "Countdown", but did not win the game.
GOOD LUCK ALL!
PLEASE REVIEW THE SPECIAL "COUNTDOWN" GAME RULES SHOWN ABOVE MARKED WITH A "*"
Following are the re-set 2024 NHRA "Pick 'Em" game points:
2000.0 - Budnicks (FBBO)
1975.0 - TT5.9mag (FABO)
1974.5 - stroked340 (FABO)
1964.5 - cuda20 (FABO)
1954.5 - Outlawd (FBBO)
1949.5 - Yunick13 (FABO)
1948.0 - 64BEL (FBBO)
1945.0 - ocdart (FABO)
1944.0 - GTXDAN (FBBO)
1934.0 - Duster79 (FABO)
1924.0 - Back in Time (FABO)
1914.0 - memike (FABO)
1904.0 - johnnycuda (FABO)
1894.0 - alsant (FBBO)
1884.0 - SSG_Karg (FABO)
1874.0 - Nick2317 (FBBO)
The point spread difference before the re-set was 302.0 points. Now, it's only 126.0 points.
This is still anybody's game and it's going to be exciting with a lot of position movement over the six-race Countdown.
PLEASE don't forget to post your picks before the start of qualifying for each Countdown race if you do not have "locked" picks!
There are no pick carryovers and there will not be any reminders to post your picks for the remainder of the game.
GOOD LUCK ALL!
Just in case any players with "locked" picks may have forgotten who they have "locked", here is a list of what my records show:
64BEL (FBBO)
TF Justin Ashley
FC Austin Prock
PS Greg Anderson
PSM Gaige Herrera
Back in Time (FABO)
TF Antron Brown
FC Austin Prock
PS Erica Enders
PSM Gaige Herrera
Budnicks (FBBO)
TF Steve Torrance
FC Austin Prock
PS Greg Anderson
PSM Gaige Herrera
cuda20 (FABO)
TF Brittany Force
FC Matt Hagan
PS Erica Enders
PSM Gaige Herrera
Duster79 (FABO)
TF Justin Ashley
FC Bob Tasca III
PS Erica Enders
PSM Gaige Herrera
johnnycuda (FABO)
TF Justin Ashley
FC Austin Prock
PS Greg Anderson
PSM Gaige Herrera
memike (FABO)
TF Steve Torrence
FC Bob Tasca III
PS Erica Enders
PSM Gaige Herrera
Nick2317 (FBBO)
TF Doug Kalitta
FC Matt Hagan
PS Erica Enders
PSM Gaige Herrera
SSG_Karg (FABO)
TF Doug Kalitta
FC Ron Capps
PS Erica Enders
PSM Gaige Herrera
Yunick13 (FABO)
TF Steve Torrence
FC Bob Tasca III
PS Erica Enders
PSM Gaige Herrera
If you are not listed above, then I do not have "locked" picks for you and you must post updated picks before each upcoming race in the 6-race Countdown.
Damn I knew I had decent picks
but hell ya' I'll take it
thanks to @ocdart for the game
& thanks everyone, who plays
To get locked in do you have to pick Gaige Herrera? Asking for a friend :p
It would seem so, but no.
Looking back over the season there was one race where there were actually four different Pro Stock Motorcycle drivers picked, one race with three different driver picks, and two races with three different drivers picked. The other five races to date have been split between either Gaige Herrera or Matt Smith with the overwhelming number of picks for Herrera.
Obviously, this is the result of his success but (JMO) I would like to see more parity in the class. I believe it would add to the number of entries and cut down on the increasingly short fields in Pro Stock Motorcycle.
Don't know if anyone caught this but in the first round of eliminations for funny car when Daniel Wilkerson grenaded the engine and the body folded up, the chutes didn't deploy. He got it stopped down the track. Apparently the fix they instituted after Forces crash didn't help.
Maple Grove is next... Sept 12-15
I noticed, & said the same thing while watching it... :realcrazy:
they are gonna' get someone killed, tethering them bodies to the car, IMHFO
Here's your "Tuesday Before the Event" reminder for the 40th annual Pep Boys NHRA Nationals, September 12-15, at Maple Grove Raceway in Reading, PA.
Please post your picks before Pro Stock and Nitro qualifying starts so you will be eligible for all event bonus points. The first of the scheduled four rounds of Pro qualifying is scheduled to start at 2:30pm EDT (11:30am PDT) on Friday.
nhra.com currently shows the following number of entries:
* 19 Top Fuel
* 16 Funny Car
* 21 Pro Stock
* 14 Pro Stock Motorcycle
Those counts are always subject to change so make sure to check to make sure your driver picks are entered.
Please check nhra.com to make sure your picks are competing in this event.
The current weather forecast for Pro qualifying at Indianapolis, IN, calls for
* Friday - sunny with a high of 82F
* Saturday - sunny with a high of 85F
* Sunday - sunny with a high of 84F
The current television schedule for the Pep Boys Nationals...
* Qualifying Show 1: 7:00-8:30pm EDT (4:00-5:30pm PDT), Friday, September 13 on FS1
* Qualifying Show 2: 12:30-2:00pm EDT (9:30-11:0apm PDT), Sunday, September 15 on FS1
* Final eliminations 1: 2:00-4:00pm EDT (11:00am-1:00pm PDT), Sunday, September 15 on FOX
* Final eliminations 2: 4:30-6:30pm EDT (1:30pm-3:30pm PDT), Sunday, September 15 on FOX
All television coverage will also re-air at later times. Check www.nhra.com.
Pep Boys Nats
Sticking with my "locked in picks" still...
ride them (race) horses, till they buck ya' off
Good luck everyone
PEP Boy Nationals
TF B Force
FC A Prock
PS G Anderson
PSM G Herrera
Good luck guys!
2024 40th annual Pep Boys NHRA Nationals qualifying leaders:
Q1
Weather: 82F, 48% relative humidity, barometer 30.19", adjusted altitude 2,353', track temp. 119F
TF: Clay Millican, 3.762 @ 331.36
FC: Alexis DeJoria, 3.915; Bob Tasca III @ 331.53
PS: Erica Enders, 6.535 @ 210.34
PSM: Matt Smith, 6.801 @ 199.49
Q2
Weather: 75F, 61% relative humidity, barometer 30.18", adjusted altitude 1,993', track temp. 106F
TF: Justin Ashley, 3.713; Doug Kalitta @ 335.73
FC: Austin Prock, 3.849 @ 338.43
PS: Erica Enders, 6.535 @ 210.54
PSM:
Q3
Weather: 81F, 54% relative humidity, barometer 30.23", adjusted altitude 2,328', track temp. 115F
PS: Dallas Glenn, 6.530; Erica Enders @ 210.57
PSM: Gaige Herrera, 6.743 @ 200.20
Q4
Weather: 84F, 48% relative humidity, barometer 30.20", adjusted altitude 2,517', track temp. 118F
PSM: Gaige Herrera, 6.743; Matt Smith @ 200.50
Somehow 'ocdart' (FABO) stumbled into picking all four #1 Pro qualifiers for the 2024 40th anniversary Pep Boys NHRA Nationals Top Qualifier title with a total of 32.0 bonus points.
'64BEL' (FBBO), 'johnnycuda' (FABO) and 'Yunick13' (FABO) shared the runner-up qualifier with 31.0 bonus points each.
Way to go!
More great picks!
16 players again this week and 14 different driver combos made up of:
* 5 different Top Fuel drivers with one Round 1 head-to-head matchup between #6 qualifier Steve Torrence (1 pick) and #11 qualifier Brittany Force (3 picks). There is also a possibility of a head-to-head matchup in the second round of eliminations if both drivers survive Round 1.
* 4 different Funny Car drivers with no Round 1 head-to-head matchups. There is a possibility of one head-to-head matchup in the second round of eliminations if both of the drivers survive Round 1.
* 3 different Pro Stock drivers with no Round 1 head-to-head matchups. The earliest possibility of a head-to-head matchup is in the semi-final round of eliminations if both drivers survive until then.
* 2 different Pro Stock Motorcycle drivers with no Round 1 head-to-head matchup. The only possibility of a head-to-head matchup is in the final round of eliminations if both drivers survive until then.
Good luck all!
Here's your "Tuesday Before the Event" reminder for the second event of the 2024 Countdown, and the middle of three consecutive weekends of racing: the 16th annual NHRA Carolina Nationals, September 20-22, at zMAX Dragway in Concord, NC.
Please post your picks before Pro Stock and Nitro qualifying starts so you will be eligible for all event bonus points. The first of the scheduled four rounds of Pro qualifying is scheduled to start at 4:00pm EDT (1:00pm PDT) on Friday.
* 18 Top Fuel
* 15 Funny Car
* 19 Pro Stock
* 15 Pro Stock Motorcycle
The current weather forecast for Pro qualifying and Sunday finals at zMAX, calls for
* Friday - mostly sunny with a high of 80F
* Saturday - sunny with a high of 81F
* Sunday - mostly sunny with a high of 74F
The current television schedule for the Carolina Nationals...
* Qualifying Show 1: 7:00-8:00pm EDT (4:00-5:00pm PDT), Friday, September 20 on FS1
* Qualifying Show 2: 1:30-3:00pm EDT (10:30-Noon PDT), Sunday, September 22 on FS1
* Final eliminations 1: 3:00-6:00pm EDT (Noon-3:00pm PDT), Sunday, September 22 on FS1
Man TF has kicked my *** all season.
CAROLINA Nationals
TF J Ashley
FC A Prock
PS G Anderson
PSM G Herrera
Good luck everybody.
