Coelacanth
- 5:02 AM
- May 10, 2024
- Edmonton, Alberta, Canada
I was under the front end to double-check the routing of my new fuel lines and checked the steering components for play. Everything was tight except for the Pitman arm link. I noticed right away something was amiss because there were no cotter pins on the castle nuts for the Pitman arm and link, and the one on the Pitman arm was loose. I went to tighten it and the Pitman arm stud simply spun with the nut, so there's no way to tighten it. This means a new Pitman arm, correct?
