Drive line
B-Body 70
7:50 AM
Modesto Ca
Any thoughts on drive lines? Both my 70 and 69 b-bodys missing drive lines.
What is your definition of a driveline?
Complete drive line and trans yoke from trans to the rearend. My cars never had them . I’m in the process of getting my 69 charger drivable and putting my 70 GTX together after 20 years the charger is a servivor but has no drive line.
Sounds like you need a couple of driveshafts.
Yes sir. I know I can get them aftermarket or have them made but just wanted the mopar expertise family to give me some insight on this before I do my own thing.
Thanks!!
The Charger had the 8-3/4 swapped for a Strange S-60 4:10:1 Spool, 1350 U-Joints (and yokes), Mark Williams 3.5" Chromoly driveshaft.
For the Coronet 500, building a 489 case 8-3/4" 3.55:1 Sure-track II diff, crush sleeve eliminator, 1350 yoke for another 3.5" Chromoly driveshaft.
The Coronet Convertible has a factory Dana 3.54:1 with clutch type limited skip and the Mopar 7290 U-Joints (almost the same size as the 1350, but with internal snap rings.) The Driveshaft is what came with the Kessler 5-speed conversion, and has a driveline vibration which I haven't check driveline angles yet?
