CP Pacesetter CP864 Air Sander
493 Mike
8:54 PM
White Cloud, MI
Hi fellas,
The air inlet throttle valve on my DA broke. Has any one found a replacement part? CP has discontinued production of this little plastic item. KF124233.
Can you post a picture of the part?
It has disintegrated. I decided to make one though. First attempt proved I can make it work, so I'll change some dimensions tomorrow. I am using Delrin plastic and my lathe. Thanks for the response.
Found this, if it looks right.
That could be the correct part! Where can I find it?
Thanks!
Did you look up the part number? There should be exploded parts views on the net.
I finished the replacement Delrin throttle valve for my CP Pacesetter DA and want to report it works great.
