katmachine62
I have a 62 Dodge Dart Sedan (in Australia) which I've had a stroker 318 Poly (now 392) built with mild cam (222@.50, .450 lift, running a 2bbbl Holley 500cfm (AFR's: 12.8 - 13 @ Idle and Cruise, into the 10's under load). Everything is new, and engine is balanced, 10:1 compression, running standard 727 with 3.23 rear end. I only run 98RON Octane Premium fuel...
However, from day one, I have only been able to run approx 3/4 degrees of intial timing without suffering detonation (under load at approx 2800/3000 rpm).
I had the original Distributor completely rebuilt and Pertronix 2 module added. Specs as follows - Base timing should be -/+ 14 BTDC, Curve - Mechanical Advance starts at 1000 rpm, has 12 deg @2000 rpm, and 16 deg of Total at 3600 rpm (3600 - 4000rpm is the max my engine will ever pretty much see) Vacuum Advance is 21 deg at 19" of Vac, just for reference.
Interestingly, at 8/10 deg BTDC of initial timing the car starts a lot easier, and runs substantially cooler; at 3 degrees I need to give the engine about 6 full pumps of the throttle to cold start, and the engine runs approx 20% hotter!
Before I spend more money seeking expert shop opinion, dyno testing etc., thought I would run it past the brains trust here for any helpful insights... thanks in advance...
