Convt Top Gaps in Corners - Normal?
PurpleBeeper
12:08 PM
Chicago
I’m picking up my car after getting a new convertible top installed. I see big gaps in the corners. Is this normal? If not, how do I fix this?
I don't recall any gaps in mine. My convertible is up on the lift right now. I'll be bringing it down this weekend when I finish working on the car below it. I'll take pictures and post them.
Thank you. I left my car at the convertible top shop because of this. I appreciate your help! Also, if you don’t mind, please take a peek to see if there is some type of foam or something between the rear window “curtain” and the top itself in the corners holding the corner of the top up & flush with the body. I “think” mine had that at one time????
Pretty detailed video here.. Music to sooth you. Also has massive gaps too.
This video had a 68 RR and the gaps are way better. But still don't look tight.
Grabbed this from the video.
does the top frame have adjustment? I've yet to mess with one on a Mopar
looks like it needs to be raised up?
Pretty typical of a 66-70 B body vert.. The trim curves to follow the body lines and the top has a hard time matching the trim...
Hi Guys, I am currently restoring a 70 coronet conv. The original trim pieces had a harden caulk on them. After re-chrome, I installed the the chrome into a bed of automotive strip caulk. removed the excess and smoothed gaps over with soft mineral sprits rag. It is paintable.
Here is the product if interested.
amazon.com/TP-Tools-White-Automotive-TP-1071/dp/B074FGFZ17/ref=asc_df_B074FGFZ17/?tag=hyprod-20&linkCode=df0&hvadid=693070740373&hvpos=&hvnetw=g&hvrand=11802009245400501582&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021525&hvtargid=pla-645380628229&psc=1&mcid=5a5eb4de179135ea9a7afaf88d0a62b4
Thanks! Dang, that gap looks like water would flood in there more than the drip tray could handle. That is similar to my problem, but the red car isn’t as bad
Dang. Do they flood in the trunk like that? I seem to recall a top shop putting some pieces of foam in there many years ago to cure this problem. Have you ever seen that?
Also found this in the shop manual. Make sure they have the side retainers installed. Thats what I think seals the top to the rear and side. If you have the shop manual section 23-157
If you need a downloadable shop manual here is the link. https://www.mymopar.com/downloads/servicemanuals/1970_Plymouth_Service_Manual.zip
Thanks! Yes, the side rails are installed. It “looks” like you’d need to raise the back part (only) of the side retainer rails to seal the corners. The shop owner talked about some side rails having an “upward extension piece” on the back end to take care of this (non-Mopar). I’ve also wondered if they got the side retainer rails on backwards (left/right)?
Noticed something in your pictures. I may be way off here but those retainer rails could be on the wrong sides. They both curve down towards the back.
Yep, I asked the shop the same thing. The owner said he would swap them, but charge me extra labor and he doesn’t think it will help???
I've seen cars that had the tack strips manipulated to try to push the top higher into the corners, it winds up with big wrinkles near the window... The top wants a natural curve, the designers didn't....
Thanks R/T. I installed the last top (poorly) and I added some tacking strips like you mention and I did get wrinkles. Do you know how to get the top into those corners a different way? I “think” I remember some foam shoved up in those corners by a previous top shop 30 yrs ago (?). A guy at Moparts posted a pick of his green 69 GTX convertible. This is how I remember the fit on a previous top
There are a bunch of top adjustments, but there isn’t one to take care of this problem (that I know anyway)
Interesting thread.. I’m working on 68 and it was a poor fit in the corners as well. I’d like to find the correct hardware for tack strips and new tack strip inserts.. mine are a little rough
I replaced my tacking strips with rubber trim. The shop says you can buy it on rolls now somewhere?
