CLUTCH ADJUSTMENT
paul1969cars
5:29 PM
new york
Hi
I have two b bodies cars
one with 838 and 4 speed
one with 440 and 4 spd
both with new borg and beck clutch with original overspring installed under dash
Is there a way to adjust the clutch
The 383 set up grabs so high
and
the 440 setup grabs ok but pedal is so easy and not stiff
I ruined a clutch because I adjusted for the free play at the pedal. The throw out bearing was riding on the pressure plate fingers and the bearing seized.
Now I adjust it down below. Remove the inspection cover and adjust the air gap between the bearing and the PP fingers to about 3/16", cycle the clutch and check it again. . Let the pedal height be what it is. It will work perfectly.
THANKS
WILL LOOK AT
