Well at least he had spark.Had a kid in tech school automotive with a GM that had points sight window to set points and sprayed starting fluid in there to start car. Talk about kaboom
I agree but we were like WTF was that!!!!Well at least he had spark.
Remember, I was not an office guy. I was a Carpenter. The entire "4 column table" is absolutely foreign to me.KD - just to cover all bases in a one shot review, would you care to make a 4 column table with both cars in the far right columns and the far left column for components and date installed so we know how new they are, then for each row list each component so you can see at a glance each component that is the same or new for each car and which components are not. I know this is in your head and you've tried everything, but maybe listing it all out in one table will present an ah-ha moment.
Now sans table - going off the wire jiggle method and possible ECU reliance on voltage, if your battery is already low or problematic, then any loose connections or increased resistance will make things much worse. Have you ever swapped batteries from Jigsaw to Ginger? Remember that Ginger's battery is in the trunk and Jigsaw's is under hood, correct? Another thing that comes to mind - in the table list you should also include all electronic accessories - for example, does Ginger have A/C and Jigsaw does not? Does Ginger have a radio and Jigsaw does not? I had an issue one time in my 67 in high school where I had a radio wiring issue causing a parasitic draw. My buddy helped me figure it out when we were installing a car alarm. Another time on that same car, one of my door jam switches that turns on the interior lighting when you open the door was sticky.
Do the table - even if you think it's a waste of time. You're retired anyway. DO IT!![]()
Easy brother. Across the top put things used and side the cars and check each item per car used and see a pattern or how many have had replacement partsRemember, I was not an office guy. I was a Carpenter. The entire "4 column table" is absolutely foreign to me.
Did you do anything with the bulkhead connector?
Well dang it Greg, you stay up most of the night posting and trying to keep up with 'all' of it isn't exactly easy. Just because you don't sleep much doesn't mean we don't. Not 'everyone' is 'like' you are!!!![]()
Maybe you didn't work hard enough to make you tired!!?? LOLOh yeah, back in May I pulled the plugs and cleaned them with DeOxit, Then packed them with dielectric grease.
I'm usually up until 2:00 AM Pacific time. It really is my nature to stay up late. The years in construction made it a struggle to get to sleep before 10:00.
Thats why you just buy a new one.. Instead of trying to fix something that has either worked for years and has finally met its fate or its a new Chinesium knockoff that has a limited time any way. Im not sure what that stuff is that they seal those things in but its like tar. As far as capacitors you could probably read the ohms or look for a expanded capacitor. And for all the other stuff on the board who knows I'm certainly no expert but was just talking crap.PROBABLY......means what....there are only two capacitors used in the dwell timing network...which one??. What about the diodes and pilot transistors.....maybe the paint color is incorrect....probably. The "goo" keeps the uneducated from performing "surgery" on something they know nothing about.....
BOB RENTON
how do you test for a failed pickup in the distributor?I have had many distributor pick up units fail.
I almost used one of those in my build, but I've read a few reports of these failing. Could be faulty install, but I didn't want to spend that $ and take a chance, so went with Firecore instead and kept the Mopar Chrome box ECU.The troubleshooting notebook has nothing in it to test the ECMs and I've had no luck finding information elsewhere.
Despite the admonition from ignorant critics, I've saved parts that failed so that I can test them later. This has worked to my advantage because some parts that were thought to be the problem actually worked fine when tested later.
Hey...I don't live in a 200 square foot New York apartment...I have plenty of room to store spare parts.
I've considered the possibility that a component that suddenly stopped working may have done so due to heat or a poor connection. Testing that component on another vehicle is a cheap and easy way to find out if it is work saving.
Oh, and the reason that I have saved the ECMs that are absolutely known to be dead? I've seen some guys gut the insides out and mount a GM HEI module inside. This gets you electronic ignition that is reliable and looks similar to what you already had.
I've thought about this option:
| Component | Date Installed | Jigsaw mix and match Charger | Ginger Red Charger |
| Spark Plugs | |||
| Spark Plug Wires | |||
| Distributor | |||
| Distributor Cap | |||
| Battery (you get the idea) |
the new solder contains no lead and thats why solder joints are prone to cracking.
There you go
Component Date Installed Jigsaw mix and match Charger Ginger Red Charger Spark Plugs Spark Plug Wires Distributor Distributor Cap Battery (you get the idea)
The FBBO top bar here even has an insert table function (to the right of the " )...you learned something!
Or the fellow who bought might offer a testing serviceMaybe Ray has a tester for your application?
FOR SALE - Mopar factory electronic ignition testers P/N 1-3500 NOS?
