- 3:05 AM
- Apr 13, 2012
- Granite Bay CA
Please, no.
Not so fast!!..Say his name 2 more times----------------and he'll show up.![]()
My engine turned 550 HP and 675 Lb Ft of torque when I ran it on a chassis dyno at the Hot Rod Power Tour (as driven on the tour: full mufflers, air cleaner on, etc.). This was a "fun run" event, so I had no opportunity to tune anything. The horsepower dropped off after about 4900 RPM. Something was going on, and it likely is a fuel delivery problem. With 675 torque, Horsepower should be up over 600. But I haven't had time to diagnose the issue and find that lost HP.
EVERY TIME. Also, my father-in-law's shop won't even build a flat tappet engine without lifters that direct oil the cam (they do this through a small hole drilled in the bottom or a small groove in the lifter that allows oil to seep through on to the cam).
That's the other thought that came to mind, but my spring pressures are decent: 140# seated and 325# open. And these numbers are for "broken in" springs, not new ones that lose a few pounds after running. It just doesn't seem reasonable that these springs would start losing control at 4900 RPM?This dyno?
[/URL]
If so, loss of valve control IMO
You know, part of what you said just tweaked my curiosity (in red).It's not just pressures but can also be weak pushrods, springs very far away from coil bind at max lift, heavy components (large diameter springs/steel retainers, heavy valves).
Just my guess as my 426 hemi dyno looked just like that when I first got it. (And it suffered from everything I mentioned above.)
Thanks for the thoughts - again, much appreciated!Weight will make MUCH more difference on the valve side.
So lightweight valves, springs/retainers/locks are very helpful. Rocker weight can make a big difference.
Pushrod weight and lifter weight I'm sure can influence things but it doesn't seem to.
So you want the stiffest pushrods regardless of weight or you can get a pole vault effect.
I thought you were flat tappet.
For hydraulic roller, even with beehive I would think it needs at least another 25lb seat pressure and 50lbs over the nose.
The lifter and pushrod weight don't seem to influence much as it's moving 1.5 -1.8 times slower and less distance than the valve side. (whatever the rocker ratio is)
Hawk, are you still running the beehive springs?Thanks for the thoughts - again, much appreciated!
I have aluminum roller rockers, aluminum Edelbrock heads and high quality stainless valves.
I'm not sure why lifter weight doesn't influence things - the mass of the lifter still has to be stopped and pushed down after max lift on the cam. Regardless, I agree with the spring pressure thoughts and I plan to increase spring pressure a bit.
Having said all that, I still believe the most likely culprit is fuel delivery. This engine combo was owned previously by @qkcuda
I bought the engine from him and freshened the engine since he had it, but his car ran well without these issues. The only notable change since he had the engine is the fuel induction and, of course tuning. Dave used a carb and I am using F.A.S.T. fuel injection. I am also controlling timing through the computer.
I have hijacked this thread enough, but at least I hope others find this discussion helpful regarding valvetrain and cams.![]()
Yes. They measured (obviously used) at 140# seated and 325# open. Since spring always lose a bit in the first few hundred miles, I'm guessing they would have been north of 150# seated when brand new.Hawk, are you still running the beehive springs?
Go to YouTube Powell machine has a whole series of videos on cam failures. This one is showing how they check and what to look for when checking new liftersMost of us have heard of how engines with flat tappet camshafts have had increased failures in the past 15-20 years. There are a bunch of opinions on what is to blame but so far, I have seen no 100% smoking gun on the exact cause. The potential causes are numerous.
Reduced zinc in oil.
Camshafts and lifters made with softer metal than before.
Lower quality machining from Chinese factories.
Lifters that don't spin in the bores.
Valvesprings too stiff.
Improper break in.
Etc, etc....
While all of those things may be true AND if you have more than one of those situations together, the chances of a failure seem to grow exponentially.
I know that there are several threads on this site covering this topic, I was hoping to expand a bit on what has already been mentioned.
Being one with a curious mind, I wonder about a few things...
We have been told that with flat tappet systems, the lifters mate to the lobes. How? I've read that they establish a pattern to each other and that to swap in another lifter, it must be NEW and that the "break in" starts all over for that lifter.
Why? Has anyone ever published pictures and measurements of the actual wear patterns?
Who remembers Jim LaRoy/IQ52 ? he mentioned before that he has swapped lifters around and even reused them in dyno testing and had no failures. How is this possible?
I remember a buddy going out to the junkyard and pulling a couple lifters from an engine to swap into his engine. He had a couple sticky lifters in an old beater. I don't recall any future troubles that he had.
I did the same to a stock 318 years ago.
I built MY first engine in the 60s. Nothing I’ve said is incorrect (edge meaning even .0001 from center is considered edge), cam gets smaller when grinding, in a sense it does but only on the base, when wanting more lift, too bad you can’t understand this. I know who’s talking rubbishCeedawg,
I am not the idiot. Have a look at how many ticks your posts are getting........
You are making wrong statements. Get it? I am correcting them so that others do not absorb your faulty advice.
I don't need to 'read the internet', as I was building engines & fault finding looooong before the i'net arrived.
Don't write rubbish & then nobody will question your info. Grow up!
Isky built the cam-rollers and rev kit for my engine (70s) the rev kit (springs over push rods to a rack under heads) on a general look see I found my valve springs had many 10 pounds seat pressure, I could turn retainer with thumb and finger. Engine had been turning 6800 like that. I changed springs that day.The lifter and pushrod weight don't seem to influence much as it's moving 1.5 -1.8 times slower and less distance than the valve side. (whatever the rocker ratio is)
Oh I’m glad I found it out before but the rev kit did save that engine.. those springs had considerable strength, the Max heads had no heat crossover so I made a stud to hold the bracket square in that spot.Not a fan of rev kits myself nor do I think weigh matters on the lifter.
I see high end titanium valves. I've never seen a titanium lifter.
As for turning 6800 with a rev kit and 10lbs on the seat, I think it would be very unhappy and your pistons were probably closing the valves.
