SOLD 1966 Dodge Coronet Deluxe 2 door Sedan
coronet-flyer
1:44 AM
Woodstock, GA
Feedback: +0 / =0 / -0
Rust Free 66 Coronet
Legal Fun on Wheels!
Exterior Color: Midnight Black
Interior: New Gold Upholstery, Seats, Seat Belts, Door Panels, Carpet, Floor Mats, and New Seat Foam.
Glass: All glass is original, except windshield. All windows roll-up & down, no cloudy or delaminated glass.
Engine: LA318, Mild street cam, Electronic ignition, New Edelbrock 1406 600cfm, 4 barrel carburetor with automatic electric choke on Edelbrock Torker intake manifold.
Lights: Headlights, Taillights, Brake lights, Turn signals, and Dash lights All work.
Instrument Cluster Gauges: Gauges have stopped working. Based on my experiences the usual fault is the voltage limiter on back of instrument cluster. Replacement part is available from most MOPAR classic parts suppliers.
Mechanical Gauges: To ensure engine is operating properly installed mechanical Temperature and Oil Pressure gauges.
Fuel System: New fuel tank, fuel tank sending unit and filter, fuel line, and fuel pump.
Drive Train: Automatic 727 Torqueflite transmission, 8-3/4 open 3:23 differential with casting number X2070741.
Speedometer: Just recently Speedo needle started bouncing, now it’s not working. Based on my experience it’s either the speedometer cable or the speedometer gear, both parts are available from after market suppliers. To ensure correct speed purchased new HUD, GPS driven speedometer. Not installed yet
Exhaust System: Full length headers, New 3” dual exhaust, mufflers, and hangers.
Power Brakes: Front disc, Rear drum, Newer remanufactured power brake booster.
Wheels & Tires: Chrome
16” Edelbrock 409’s mounted
on BF Goodrich Comp T/A’s
225/55R16.
Chassis: New Subframe connectors
Rear Wheel Wells: Mini-tubbed.
Suspension: New HD 1-1/2” front sway bar, polyurethane bushings. Newer front, rear shocks, and leaf spring bushings.
Coronet produced in St. Louis, MO assembly plant as a Deluxe series with a 273 V8. More pictures are available. Thank you for taking the time to read the ad.
This ‘66 is a fun and enjoyable classic car to drive and out cruising it always gets a lot of smiles and thumbs up.
Price: $ 10,500.00 Sold as is, no guarantees or warranties expressed or implied.
Can you show pics of underneath? Was this car always in the south....any history prior to you & how long have you owned it?
Were the torsion bars adjusted to get the front end up so high and what besides possibly air shocks, raised the rearend so high?
