904 transmission mount
snake
1:16 AM
canada
Good day all,I am looking for a tyranny mount,is there anything better now a day's have allways got an Ancor, but after having my Ancor engine rubber mount tear in half,kind of leary.also in the past had a problem with the bolt being hole in the mount too small.904 transmission.what you think.cheers.
This is an FYI about the poly mount, which you should use, and I fully reccommend.
They were designed to fit into a factory metal spool mount body.
The aftermarket mount is slightly different and can lead to cursing trying to trim and instsll.
This is an FYI about the poly mount, which you should use, and I fullu reccommend.
Any pic of this mount never heard about mount.good info
