How to retrieve saved drafts.......
'68 Charger
6:13 PM
Akron, Ohio
Probably a simple task but I cannot find out how to revisit a Market Place ad that I created and saved.
Any help would be greatly appreciated.
Click on your user name on the top right of the screen. There is an option "your content". That will let you see all the postings you have made.
If you are on your phone, turn it horizontal. Click on your user name and directly above it will be "Bookmarks".
Yep, tried that too with no luck. Both on my phone and my desktop.
Thank you.
I wonder if it has anything to do with being a Gold member which I am not.
Did you look here - - - - - - >
Just tried with no luck. Thanks
I believe that the fact a saved drafted is not considered a post, activity, content, attachments etc. No where to be found even though FBBO has the feature "save draft".
. test
I tried to make a draft - saved as a draft, then left it for 20 minutes plus while searching for a way to retrieve it.
I came back and the draft was where I typed it...... so I can pick it up and carry on. Not sure what the timeout on the unsaved post will be - might be similar to the editing time on any regular post that is made.
I searched and found nothing. I'll leave my draft up and see what happens to it.
BTW ..... have you been back to the Marketplace and searched for that draft post you made?
If you mean a post you started and never posted, go back to that thread and it should be there as if you were still typing it.
As I said above, there might be a timeout on how long the draft stays alive.
