Belvedere408
- 11:54 AM
- Jan 25, 2023
- Springfield Oregon
I've always changed my own oil, can't imagine some other dumbass doing it.
Not necessarily on a Gen 5 RAM. The filter is worse to change than on the old B and RB engines and K-members. The suspension is tight under the RAM filter and it’s pretty much assured oil will go everywhere. I tried covering the steering with newspapers to deflect it off but still got some pieces coated. I’ve read of some owners who use fast-lube services and apparently they just let it go and coat everything and it drips in their garage/driveway for weeks.The only annoyance is the undershield removal on my modern hemi's. The filter is easy.
My Kia dealer was the cheapest for oil changes. If you dont get an Kia oil filter it will void the warranty.Took our newer car in for an oil change and tire rotation. 45 minutes and $98.84 later. $71 went to labor. The car- 2023 Kia Sportage with 11k miles on it. I miss having my neighbors lift.
I keep considering a tire machine, but seeing I can still go a mile down the road and get 4 tires mounted, new stems and balanced for 50 bucks cdn cash... not gonna happen.
Egad ! Yuck. I was referring to my 2 modern hemis, unaware of the G5 Ram issue.Not necessarily on a Gen 5 RAM. The filter is worse to change than on the old B and RB engines and K-members. The suspension is tight under the RAM filter and it’s pretty much assured oil will go everywhere. I tried covering the steering with newspapers to deflect it off but still got some pieces coated. I’ve read of some owners who use fast-lube services and apparently they just let it go and coat everything and it drips in their garage/driveway for weeks.
My Mack Superliner with 998cu.in. V8 takes 14 gal. of oil and three filters.Lol, memory is going but I think you’re talking over 10gal. of oil +++ 2-3 oil filters each time.
Plus 1/2hr just to hit all the grease fittings!
Short hauling, 16,000 miles, or about 300 engine hours.I’m curious, how many miles do you get between oil changes?
