Home Depot compressor sale
GTXDAN
3:33 PM
Georgia
HD has a 60 gal Husky compressor with cast iron compressor for $799. This is in store only, not online.
60 Gal. 3.7 HP 1-Phase 175 PSI Oil Lubed Belt Drive Stationary Electric Air Compressor​
Husky 60 Gal. 3.7 HP 1-Phase 175 PSI Oil Lubed Belt Drive Stationary Electric Air Compressor
  • 92% longer air tool runtime vs 60 gal 2-stage 175 PSI compressors
  • 45% higher CFM air delivery vs 60 gal 2-stage 175 PSI compressors
  • 34% faster pump up time vs other 60 gal. 175 PSI compressors
  • View More Details
This item isn't eligible for online order Pickup, While supplies last. See low price
More delivery methods in checkout
Delivery Details
This item is only returnable in store.
Product Details​
About This Product​
The Husky 60 Gal. oil lubed belt drive air compressor is industry leading with 2-stage performance in a single stage pump. This air compressor provides 92% longer air tool runtime compared to 60 Gal. 2 Stage compressors with 175 maximum psi and 7.9 SCFM at 90 psi. The heavy-duty, cast-iron, 2-cylinder pump is oil lubricated for a long life and delivers 11.5 CFM at 90 psi which provides 45% higher SCFM air delivery versus typical 60 Gal. 2 Stage 175 psi compressor with 175 Maximum PSI and 7.9 SCFM at 90 psi. The poly-v pulley and drive belt provides smooth operation of the air compressor with less vibration. In addition, the high efficiency aluminum flywheel is engineered to provide maximum air flow and allows for an efficient and smooth start-up. The Husky 60 Gal. 175 psi air compressor is perfect for a small shop, automotive enthusiast or serious DIY user. This unit features a 208-Volt to 230-Volt electric motor. It should be connected to a power supply that is 230-Volt, 60 Hz, AC only. Please consult your local codes and a certified electrician before wiring this compressor for power. This compressor does not include a power cord.
Highlights​
  • Cast iron pump and cylinder for improved durability
  • Poly-v pulley and drive belt provides smooth operation with less vibration
  • High efficiency aluminum flywheel provides maximum air flow and lower start-up amps due to less starting inertia
  • Aluminum head and valve plate to maximize heat dissipation
  • Large capacity, 60 Gal. ASME tank at 175 maximum psi, with a large 3/4 in air outlet port, provides more air for longer run times for on air tools such as ratchets, impacts, spray guns, hammers, etc.
  • Oil level sight glass and easily accessible oil fill; shipped with synthetic oil for optimum performance and long life
  • Perfect for inflation, finish nailing, framing/roofing, hobby painting, bolting, and cutting/drilling
  • Large capacity, 60 Gal. ASME tank at 175 max PSI, with a large 3/4 in air outlet port, provides more air for longer run times for on air tools such as ratchets, impacts, spray guns, hammers, etc
  • Return Policy
  • California residents
    see Prop 65 WARNINGS
7.9 CFM @ 90 is not much if you want to blast.
I had a similarly sized DeWalt unit and gave it away after a capacitor issue.
IMO blasting something the size of a valve cover requires 10 CFM @ 90 minimum.
