Cometic head gaskets
dan juhasz
3:45 PM
Whiting NJ
Are cometic head gaskets for a 426 ( 5 layer )installed as is ? No spray sealers or silicone in any common leak areas?
No sealer = read their instructions.
I install dry. I only use spray sealer when re-using them. Also make sure to have the correct deck finish surface of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
Block has never been decked. Is the factory surface adequate?
Is there a suggested upper CR on Cometic head gaskets?
16:1? Whatever the max is I guess.
Make sre the block and heads clear the rivets. If not a little clearance grind will fix it. I've used them dry. Reused them with copper spray up to 3 times. This was at 15-1 compresiion. Surface of the head and block should be very smooth.
Cometic Gasket - Sealed Under Extreme Pressure.
Yup, the 'sealer' is the coating on the gasket.....
