Still trying to get the power booster bolt out without removing dash. Got a flex extension on order. But I’ll update when it’s on the road.Tell us how it stops now.
My experience with Flex extensions is they suck, as long as your just spinning a nut/bolt not loosening or tightening they are okay but don't try to apply any significant torque...Still trying to get the power booster bolt out without removing dash. Got a flex extension on order. But I’ll update when it’s on the road.
Thanks! I'll try that tomorrow. I've taken out the dash and dropped the column five times to find a gremlin and it was crappy ignition switch. I could have dropped the column by now with all of the attempts in the past day.My experience with Flex extensions is they suck, as long as your just spinning a nut/bolt not loosening or tightening they are okay but don't try to apply any significant torque...
My choice for booster bolts (and I've R&R'd a lot of boosters) 1/4" drive deep socket 1/4" drive swivel, 1/4" drive 12-14" extension & a long handled rachet... Remove the seat... Might even remove the steering wheel just cause it's easy & the extra room is nice... Bring a good flashlight & lay under the dash.... Remove the hard one first & reinstall it last...
East coast transplant after 50 years and now out west. Agreed I probably don't need out here.I always leave those thin splash shields off my cars. They trap heat and since I don't drive the cars in the mud, they serve no purpose.
I got it loose. Just need something to get it completely out. Thanks!I do what 1 wild R/T does but use 3/8" drive and put electrical tape around u-joint. Just enough to keep from flopping around.
One of the very reasons I have multiple variations of ratchets/sockets/extensions/universals/wrenches etc plus some customized, one use only tools. Even then I sometimes have an issue to work around. Problem solving 101 at its finest!I got it loose. Just need something to get it completely out.
My 19 year old tried last night for 30 minutes who put it on there three years ago. Going to give it one more try and then drop the column.One of the very reasons I have multiple variations of ratchets/sockets/extensions/universals/wrenches etc plus some customized, one use only tools. Even then I sometimes have an issue to work around. Problem solving 101 at its finest!
Two hours? You are a magician!And customers would seem shocked when I wanted two hours to R&R a booster....
Plugs are in the same realm as the booster bolts. Watched my friend change plugs on his 351 Cleveland recently and only the ease of access made me jealous.When I changed the plugs on the wagon, I needed multiple combo's to get them out. Even had to get my Gear Wrench socket set out.
I could do it considerably faster when I was younger but I'm old & slow & don't feel like it's worth hurting myself...Two hours? You are a magician!I've been at it for four. Again, I could have had everything out and back in by now.
Soon, the column will be out.
Just curious, where did you order the 11.75 brackets from?Alright everyone -- thanks for the help! I just ordered the 11.75 brackets. I'll report back when I'm done! Much appreciated!
Doc Diff has the slider style.... The pin style ya gotten deal with "The Ram Man".. I prefer not to do business with him so that would be a no....Just curious, where did you order the 11.75 brackets from?
DrDiff they are reprosJust curious, where did you order the 11.75 brackets from?
