Valve guides
Unkle Krusty
6:34 PM
Gabriola BC
Heads are off. Bore looks good. Removed two valves. Intake is quite snug in guide. Exhaust has a small amount of wiggle. Book does not talk about valve guides, but it appears there are guides.
So, do the guides punch out fairly easily?
I will blow out all the passages while the pan / sump is off. Is there a preferred fluid for flushing / cleaning all the passages? Thank you again.UK
The FSM does discuss guides.
What are you doing for machining? Guide work is quite fussy and valve seats will need to be ground to ensure concentricity.
^^^^ the factory guide is just drilled into the cast iron. It's a slight ordeal. How many miles or K are on it
There are no guides to "punch out". They are part of the head casting.
Generally worn guides are drilled and tapped and a new bronze guide threaded in - much like a Heli-coil - "set" into the threads then reamed for the proper fit. Then the seat is done based on the guide. Not a job you'd do in your shed !!!
I had a set of heads that someone had drilled and installed solid bronze guides and cracked every port around the guide. The wrong way to do guides !!
I thought the holes were sized and the liner pressed in. Never heard of threading the hole for a screw in liner.
Teenage me took my 318 heads to the machine shop and they gnurled the guides. Never any notable issues over the six subsequent years and many miles of use and abuse.
This doesn't work very well on cast iron. When you knurl a guide you don't remove metal, the knurl process moves metal to make the hole smaller and its then reamed for the valve stem. But cast iron doesn't like to be moved around.
Its worth asking the shop doing the job though.
Thank you all for the replies. Got it. No guides to bang out. Check side play, if too much off to the machine shop and get bigger shaft valves. At the moment I am in take it apart mode. About 50,000 miles. 318 was running good. But need a bit more power. Camper van weighs 6600 loaded.
Any thoughts on flushing debri from engine. Mostly gasket bits, very small amount of sludge.
Today i will remove all the valves. Inlet seat looks good, exhaust has carbon on valve. That is from the two I removed yesterday. Now to find the dial gauge and make a bracket to hold it.
I have had a UTP guide knurling set for over 50 years now. I was taught in college how to use the tools and have done many heads over the years. My tool has a arbor that accepts a diamond edged roller (tiny) that is mounted on a angle. It is actually rolling thru the guide displacing iron that can be reamed to size. It allows a tighter than stock clearance because the groove holds oil. I would never use one of the "tap" style knurlers. I used it last on my 2008 3.8 V-6 mini van engine.
You can clean up the valves and give them the wiggle test. If they are to loose the guides will have to be replaced or lined with bronze liners at the machine shop. This will also require a valve job since the guides are never 100% in the same spot. Daily driver? If the guides aren't to sloppy? Even if they are somewhat loose? You can lap the valves with lapping compound. Apply compound to the seat. Lube up the guide and insert the valve. With the valve in the head chuck the stem in a drill. Spin the drill and pull the valve against the seat. Then move it away and back. 20-30 seconds remove the valve and look at the seat and the valve. If it has a even grey pattern all the way around on the valve and the seat. Your done. If not repeat the procedure, Usually 1-2 cycles is all it takes. Is this the best? No. Will it work and keep it running 10,000-20,000 miles or more ? Yup.
THis is the normal way to test, 2 methods shown.
Interesting test here. Never used it. But if it doesn't pass this test? My bet is the guides are pretty bad.
I did the wiggle test, interesting way to measure. But the results are in. Point 25mm. Wonderful. Above we learned that 17 thousands was the wiggle test. I think we have point 009843, which is less than 17 thou. So, I will clean the heads, and lap the seats by hand. They look good enough to do this.
My rubber bits on my hand lapping tool have gone hard. Will be interesting to see what happens when I ask for a new one.
Meanwhile, after making a bracket thing for my dial gauge, TDC occurs when the line on the balancer wheel, lines up with the middle of the marks on the cover. Close enough to the middle. 6 marks from the right, 7 marks to the left. Pin hole in the cover, fixed with JB weld.
The cam chain is toast. Lots of slack. And the main reason for this operation, is the fibre gears on the cam shaft.
Had teeth like this fail back in the late sixties.
Try the drill to lap the valves. I use a Makita. Quick and easy.
Egge Machine sells replacement valve guides for under $3.00 each
I never ream guides. I always have them honed so the valves fit better.
Just looked at the videos above. The suction test is interesting. But I checked the wiggle with a dial gauge.
Yesterday I bought a wyre wheel for my bench grinder, and cleaned 8 valves. Next week I will do the lapping. But first I need to clean the head. Hope the pump on the parts washer works. Soon I will have questions about bunging in the new cam, and adjusting the valve tension.
Did them that way back in school. Yes it rolls grooves in the guide to make them smaller followed up with a reamer to finish them to size. The grooves are also a plus for stem lubrication. It isn't a permanent fix but replacement guides don't last forever either.
If you recall, if you did not have too much clearance in the guides they can be rerolled with a larger diameter wheel at the time of the next valve job. Another plus for the UTP system.
