Looking for correct oil pan gasket
koosh
7:13 AM
CT
I have 69 SupeBee, 440 motor (not original), not sure of the year. I attached a picture of the oil pan. With a variety of oil pans possible, how do i know which fel-pro gasket to buy?
Well the block doesn't change so you can buy any gasket you're comfortable with. I'd avoid cork like the plague though!
Gasket is the same, if you go with a Felpro, get a rubber cork one at any auto store. If it has a factory windage tray, you will need two of them.
I used the summit windage tray with the integral gasket and had good results with it.
That would be a good way to go. Other vendors make them so maybe try locally. Shipping to Canada is a bitch unless you can place a $300 U.S. order - then shipping is free.
I honestly do not care for the Superformance - particularly if you have to use one on either side of a windage tray. If you DO use them you absolutely MUST use sealant on both sides of each or they WILL leak. Do NOT use silicone, use a proper gasket sealant - usually black or red stuff.
