Front Sway Bar Mounting Through K-Member
Moparfiend
12:54 AM
HOT
I just purchased a factory mount front swaybar that I assume fits through the K-Member. My Satellite never had one so I have never seen how they get mounted. I am in the process of welding the tabs on the lower control arms.
My question is where/how does the swaybar mount to the K-Member? Any pictures or drawings would be most helpful. I fount two holes on each side of the K-Member but not sure if those are the ones for the hardware.
This is what mine looks like:
Thank you in advance for your help!
Here's the nasty old originals on Fred before I got under there and re-did everything (he's a 1968, recall):
Hope that helps?
Those two holes you are pointing to are the mount holes for you 70. I posted a picture of one mounted in your last thread.
Here is the pic of a factory one mounted.
found a couple pictures from working on my 70 Charger
You can see the holes and the other picture has a small piece that goes across the holes so the bracket can mount the sway bar to
I did not take any pictures from the bottom
Awesome guys thanks a million! So the holes I pointed out are correct and I don’t need to drill any thank god lol. Ge would be nice to use factory style brackets as the plates that come with the kits look cheeky.
Same brackets on E body and 71 B Body. Not hard to find. BB and SB all the same
Show us what came with your bar. The Hellwig ones I have used are pretty beefy.
I just purchased the PST SB today so when it comes I can post. Setting up for improvement on the LCA and adding the swaybar bracket.
I just found an image of a bbody install using the same kit. This:
Hold on that may be a bbody and a PST swaybar BUT ITS NOT GOING THROUGH THE Kmember. Must be the aftermarket type?
Ur reason and knowledge lol sounds like the Wizard Of Oz
