Flywheel rubs against inspection cover
It looks like the flywheel is the problem I would not use that one.
A replacement 143 tooth 11 inch flywheel should be the fix.
It looks to me like the where the flywheel bolts to crank it is counter bored?? If yes, that flywheel is definitely the problem. You could have someone cut some off the engine side to gain clearance, but then it would need re-balanced...and I would question ring gear/starter location.
Dan i may be calling you to order another flywheel too.
Does your pan forward face angle toward the rear?
If so, maybe a shim at the arrow?
We’ve discussed shimming various locations and even shimming or using a spacer between the crank and flywheel but id like to get to the bottom of it and solve the problem rather than shimming.
I do appreciate the comment. We’ve discussed it. Just hate to shim something then put the motor in and have other but related issues.
Make a shim for the flywheel, to fit tight in that counterbore...
That is an option. Thanks. But, makes me nervous.
Want everything as it should be. Guess I don’t under why who ever had this car before me did this.
This care seemed to have taken some abuse, as they all did. Never understood why someone would paint the springs and the rear end white but whatever.
You can see photos from when i first purchased the car, no inspection cover on the assembly. So guess it’s not a new issue. Guess I should run it with out an inspection cover!! Just kidding.
Ordering a new flywheel today.
Thanks to all who participated. I don’t know flywheels very well and would’ve never thought to look at the backside and btw most photos of flywheels for purchase don’t show the engine side.
Anyone know or have any idea why this flywheel is like this????
Those photos are from 1998 BTW, purchased the car in Texas then life happened: marriage, divorce, Iraq, Job change, move, more mopars, marriage, divorce etc. etc.
This Charger is my longest relationship to date!
Examples of what she will look like below too. 4 speed, hardtop, GG1 paint, white bumblebee stripe and magnum 500’s just like when she rolled off the line in Hamtramck. One of 2,743 RT 4 speeds.
Thanks boys! Is it still ok to say that??? TRUMP 2024, VANCE 2028
I had to laugh. Painting the rearend, springs, shocks, fenderwells and anything else that showed under the car was a thing back in the late 60s, early 70s in California. It was supposed to make the underside look "sanitary". Some guys even installed small lights in the fenderwells to show them off at night...I used to wash my car every Friday after school (football season excepted) getting ready for date night or cruising and remember using a scrub brush to make sure the 'white' was clean... Oh yeah, reversing the shackles to get the rearend up enhanced the view!
Thanks for the memory...
@GTX4406 "This care seemed to have taken some abuse, as they all did. Never understood why someone would paint the springs and the rear end white but whatever."
Back in the day many of the hot rod magazines featured cars that had the differentials painted white, not sure why maybe to display how clean the bottom of the car was. I remember when extended shackles were popular and lots of guys painted their diffs white and other colors.
Unlocks a lot of horses. Even more with a decal.
So, what does right as rain mean? New flywheel is the same as the old one or now everything fits? Problem solved?
New fly wheel did not have a recess on the back of it so flywheel no longer interferes and rubs on the inspection cover. The old flywheel was the issue but still don’t know why that old flywheel was used or what it’s from.
