I was concerned with the bearing not positioned properly on the axle it may not have the bearing retained behind it if the bearing is not situated against the outside should it may move i would get it checked.
Nice picture, good to see the original clearance. That might as well be a foot compared to what I have. I'm estimating 1/32" for mine. Maybe a 1/16th if I'm lucky. That's after the studs have flattened that side of the spring off and I ground down the heads of the studs a bit. Hopefully I'll get some answers tomorrow.
All good did the same had to add an extra washer to move the the bolt back a bit left some nice score marks on the back of the rotorI made a to RMS today to get the rear end looked at. Turns out the caliper bolts, while not touching were close enough that during hard cornering were hitting the back of the brake rotor. We also reshimmed the caliper and that took care of it. Big thanks to RMS as I know that's not their normal scope of work.
Next up is my stereo install. There's too much behind where I want to mount it including my console mounting bracket. I'm just going to have to start cutting and then problem solve.
View attachment 1798510View attachment 1798511
I hadn't even heard of semi auto antennas. The pics are really helpful, thanks. Sure would be easier with the fender off, but it shouldn't be too bad. I may not actually mind having the antenna go up all the way with the radio. I'll have to see if it goes up when the head unit powers on, or just when using AM/FM. If it's up all the time, I can create my own "on" signal and install a switch to have it come up when I want similar to the semi auto.Yes I did on my Charger. First off you wanted a semi auto antenna, not a full auto. The reason why is because the full auto will extend to full length as soon as you turn on the radio. With a semi auto you have to use a switch (comes with it) but you can extend the mast as much or as little as you like.
It fits into the fender without issue but you really need to brace the bottom of the antenna because they will move around and become loose.
Here are pics of mine, notice in the one pic there are the bezels, there is also a aluminum tube cut at an angle, this is something I made to get the antenna to come up straight.
I agree that's what it sounds like, but I checked to make sure it was connected correctly. I have a power outlet in the console cubby that should have full time power. I'll check that tomorrow to see if that works since it's on the same circuit.Sounds like the memory wire is not connected to permanent battery power (Via a
Fuse) normally red or yellow
Yeah I'm running a Terminator X, but I can't help you there. I have a cable throttle body.Nothing to do with your stereo issues but are you running a Terminator X ECU? I am asking because I am just getting to the fire up stage and I was setting up the GCF wizard and its asking for type of DBW system, I am not exactly sure what the PN is for what I have as its kind of a collection of parts.
