70chall440
- 10:22 PM
- Feb 11, 2018
- Yelm, Washington
As the title says, I have a new Mopar crate engine which is a 2019 manufacture 5.7 crate engine. I got it new and installed it about a year ago into my 71 Charger. I finally went to fire it and no oil pressure. The engine ran for about seconds and died, I did this twice so about 30 seconds all in.
Some pertinent info about the engine;
Cam changed to a 6.4 cam (retained the original lifters but did swap springs)
Changed the oil pump to a Hellcat pump (brand new Mopar part)
I am using a Holley pan
I am using a remote oil filter (has a WIX filter on it now)
What I have done thus far;
I unscrewed the oil filter and it had pressure spraying oil
I disconnected the 2 lines and they both had some oil in them
I primed the engine using the bottom port and rotated the engine while doing so putting about 3 qts into the engine that way
I connected a temp manual oil pressure gauge which is plumbed into the input/return line coming from the filter going into the top port on the engine.
I pulled the fuel pump fuse and turned the engine over to see if I had pressure, none observed on the manual gauge and the electric gauge is showing 0 (actually -0 and then 0). The manual gauge line does have a little oil in it but only at the very bottom (or beginning) of the line but just a little like there is some slight pressure.
I checked the oil and it was about 2 - 2.5 qts low so I added about 3qts and tried again but got the same result, ie. no pressure.
I am thinking that the pickup (or something) isn't sealed but that the pump is trying (hence oil at the filter and in the lines).
At this point I am quite sure I am going to have to pull the pan, not sure if I can get it out with the engine in the car.
I am looking for some insight
Thanks in advance
Thanks in advance
