65 roof rail weatherstrip
Danno
9:11 PM
Akron, Ohio
Has anyone had any luck with Classic Industries roof rail
moldings for 65 Coronet 2dr?? Or is there a place that you
trust for weatherstrip.
Which are you actually looking for "weatherstrip" or "moldings" ?
DMT has all the roof rail weatherstrip for the majority of our cars.
I've used Detroit also.good customer service. The body gasket packages aren't perfect but they made it right and quickly.
Great...Ill check them out...I bought some from
(cant remember)...that look like for a diff car... frustrating..
Thnx dadsbee....just the weatherstrip..
Probably the same as my '64 but make sure... Others will have it as well as it's not a DMT produced product.
Wow....these are over double the price of 66 and up...
seems wrong...LOL
Always the way!! If you go with these Supersoft, make sure you spray some soapy water into the gap when you roll up the rear glass, so it goes INSIDE the U and doesn't pinch it down. Otherwise it's a fight to get them back on track. Rear 1/4 glass should be up in the U and then the door glass just closes against the outside of the weatherstrip.
I may have to re-check what I bought...I was tryin to
get the door glass to fit in the u....Oh boyyy!! lol
Everything is usually more and harder to find.And don't always believe it will fit until you research it.
Steel Rubber makes the correct seals. I purchased the "economy" type for my 65 and had to cut the angle in the rubber to make the glass seal. Still not perfect.
Thats what I was thinking I might have to do that too.
Thnx for the info..
View attachment 1814943View attachment 1814944View attachment 1814945View attachment 1814947View attachment 1814948View attachment 1814949
I am installing the same seals in my 65 Coronet. In your picture what holds the seals past the end of the stainless channel?
I got my car with all of the trim removed and in boxes so I am not sure if I have everything. It seems like something is missing between the end of the channel and the windshield molding, like in your picture C&P below.
There are 2 screws on the front end of the roof seal. A steel core is molded into the leading end.
