Mopar Hunter
I can’t wait to read the before and after results of a roller cam.
I’m not sure how you drive this particular vehicle, but we tend to be rough on things in my world. Have you considered putting solid lifters on the hydraulic roller cam and tight lashing it? If it’ll see some spirited high rpm action, it may be food for thought. I’m sure you’ve discussed it all with Porter.
I'll double down and ask what's the advantage over a solid roller cam?For clarity, you mean solid roller lifts, correct?
This is over simplifying, but roller cam failures happen when a lifters roller bearing gives up. When the rollers bounce it is hard on the needle bearing or bushing. If you run a solid roller lifter on a hr cam which has no lash ramp about the only lash the lifter will see is when the engine grows. So there is less lash. If we set a engine with aluminum heads to 0 cold..it is about .007 hot. Iron headed engine even less. Less lash is less lifter bounce. Hopefully prolonged lifter life more comparable to a hydraulic roller lifter.I'll double down and ask what's the advantage over a solid roller cam?
Yes, solid roller lifters.For clarity, you mean solid roller lifts, correct?
The big advantage is less weight (depending on brand/style,etc) less complexity, and the ability to turn it a higher rpm without valve float and no concerns about failure of the hydraulic lifter or sticking lifter plungers. The HR lobes are usually less aggressive and require less spring. I shift my street car at 7600 so my viewpoint is considerably different than most on this site, so take that with a grain of salt.I'll double down and ask what's the advantage over a solid roller cam?
That gear is the way to go. I’ve run one since 2019. It drives my dry sump which in turn runs my fuel pump.I called Hughes Engines today and ordered their Melonized intermediate shaft. Tom took the call and was a nice guy. They were in stock which is great since I heard they were sold out.
Yes, they’re a consumable. Every year at a minimum is typical. We’ve found tips and tricks to extend wear, like bearings and shims underneath, but they’re definitely a wear item.Dwayne Porter advised against the bronze gear based on rapid wear.
This is an interesting way to measure installed height. If I'm reading it right, you put this in place of the spring and rotate the collar until the valve is seated and the collar cannot turn anymore. That is with the collar up against the underside of the valve spring retainer.
Let's say that at that point, you get a 1.910 number and the number you're aiming for is 1.890, you would just need a .020 shim to get the proper installed height.
Greg,
I'm sure you know this but you will most certainly need new pushrods as well - the roller lifters are much taller than the old ones. When you mock everything up, make sure your valvetrain geometry is where it needs to be, then measure and order your pushrods.
Make sure you measure with the retainers and keepers you will be using. And then you may find you need modified height ones.
