P code 400 cars. Let's see your car
This is my P code 1974 charger SE factory 400 4spd.
Lets start with this... The P code is the engine desiginator in the VIN. They were usually marketed and sold as the HP (High Performance) just like any HP 360, 440 etc. They didn't call them High Output, because the bare engine on an engine dyno was (depending on the year) nearly the same. The difference in performance happened else ware down stream.
Both P and N are 4BBL 400. for 75 through 78 the P code got better bearings, a better timing chain, different emissions. Depending on the source you read 75 still got the famed 383 Roadrunner cam that was used in HP 400 and HP 383 prior to that. Cams were all the same for 76 and up. HP motors (not only P) were given more performance buy a factory change to the shift pressures/point in the trans (automatic of course) and a steeper geared rear end. Horse power ratings were measured at the wheel, so gear ration made a noticeable difference. Dual exhaust was part of the package but that went away, but could be and was often added. The same can be said for a Sure-Grip differential. Other ancillary options (towing package, HD cooling, Max A/C, etc) could be ordered with HP motors at a better price than with a "normal" motor. There are a very few options that were not normally available with out an HP; high speed A/C cut out, wide open throttle kick-down block, maybe a few others but those are the ones I know of. And those were usually on Police vehicles anyway.
There weren't too many people buying HP cars the way the did in the late 60's and early 70's, with just options for going fast. This era was saddled with government intervention so a HP car was a way to gain back some of what the government had taken away. Plus the nice things like A/C, fluffy interiors, better suspension, brakes, etc. all to make your commute easier were often added to the HP under the hood making it hard to tell if it was the engine option or something else that added things on the assembly line.
If you knew how to check the option list you could build a non-HP car that would perform as good or better than a HP version.
So in all reality there wasn't too much different when looking at components, but added all together as a package the difference was there.
What is the difference in the timing chain? Probably just the usual nylon tooth gear. What about the bearings?
I think P code meant double roller timing set. My 75 400 has that and its stamped with mopar part numbers, donor car was a highly optioned Cordoba
The 383 magnum in my '70 Charger used the nylon toothed cam sprocket. It failed at 77,000 miles and I bought the entire car in 1985 for cheap!
:thumbsup:
I think they were installed across the board by American manufactures . I read that 1969 was a poor year for dealer profits since the cars were lasting so long. Apparently there was some sort of conference involving dealers and the big 3 and that is when the decision to go to nylon gears was made ( Volvo did it too, that has been documented). Seeing that steel double roller in my 75 engine just made my day!
I had a chance, some years back, to buy an E58 Magnum GT w/moonroof, which is the lowest production engine in a Magnum in '78, much more common in '79. Only 191 were built in '78. 345 "P's" were built in '78. ( That's Magnums )
The guy bought it in Arizona, hauled it to Canada, and never took care of the paperwork. At that time it seems like an insurmountable task to get it right. So I sadly left it in it's storage container.
I used to own a '73 Charger SE. P code 400 with slap stick auto. Green on green. I don't have any pics of it on this device, except for my avatar pic.
73 Charger SE P code with a towing package out of California. Original paint. The red one behind it is a 74 U code like my current 74.
I had two P code `73 road runners, one I parted out and the other one was a red on black four speed car I sold last year as a major resto project as I just wasn`t going to get to it.
I think a P code 78 Magnum GT would be the coolest late 70's B body. If someone were to order a new Magnum in 78, equipped with the GT package, P code 400, 3.21 sure grip 9 3/4, and no A/C or other heavy, power robbing options, It would have been one of the hottest cars of the era. If only Chrysler offered a 4 speed in them....
And now stroke that 400 puppy to get some real HP. However, no Dana available.
I recently purchased this 1976 Chrysler Cordoba from California, as the owner passed away in 2024. The towing company was contacted and had a lien on the vehicle for their services and storage. A man purchased it, and that is who I purchased it from. It has the ultra-rare "P" code 400. I did send a letter to the deceased owner's son to see if he has more history of the car.
