Ideas needed to help kill door rattles
Dusty Dude
6:38 PM
TX
Hi All,
Rattles drive me nuts. I am in the process of tracking down and eliminating annoying rattles coming from the doors on my '69 Coronet 500 hard top. I have found a couple of culprits and dealt with them but now I'm looking at the linkage rods that are attached to the key lock and the door lock mechanism. Are there any anti-rattle clips available for these or some sort of home brewed way to stop them from rattling that doesn't interfere with their operation? Any help/thoughts would be appreciated.
I usually stick a thick piece of foam between the latch rod and the inner door panel to stifle any rattle. Not a bad idea to do something similar for the door lock rod the knob screws on to. Also take a look down in the bottom of the door as over the decades stuff seems to gather in them - forgotten parts, sockets, wrenches, etc.
Thanks. I do have some foam lying around. The doors are clean as a whistle.
Hi All,
Do you have the long white “shoe laces without ends” on the lock interior handle rods?
I have sets of those fabric tubes but when faced with having to take the rod loose to put them on and their questionable effectiveness, I just went with the foam. But they are the factory approach.
I recall a foam cylinder ( like pipe insulation but smaller)
Being on the rod that crosses over to the inside door handle on some of my cars
I thought the rattling was part of the mopar experience? :p
Foam with adhesive backing works well on handle and lock linkages. Sound deadening pads inside the door shell help as well for general NVH issues.
I put 80 mil Kilmat in both doors a year ago and was amazed at well it worked.
I found that the pop rivet in the bracket that is attached to the lower end of the front glass track was very loose and that the little spot weld above it had failed allowing the bracket to flop around on the post it is mounted too. Fixed all that and put some foam where needed on the various rods so now when you close the door it sounds like a fast ball smacking a catchers' mitt and no more rattles!
Thanks All.
