Adding a circuit
Dakar Timm
6:13 AM
Lake Mills Wisconsin
I'm in the begining phase of adding an aftermarket under dash stereo . Preferably I would like to tap into the fuse block . I'd really like a clean factory look .
Is there add on fuse assembly one could purchase ? I'm not of opinion that it is ok to cut into the factory wiring .
I looked here and found nothing relates to my question .
The second part ,the factory kick panels are original . There are aftermarket kick panels that have provisions for adding speakers .
Any one here have experiance with them ?
Thank you
Is it your intention to hide the head unit and keep the OEM radio? Do you intend on having both systems functional? Crutchfield supplies plug and play wiring for stereos.
Instead of cutting up kick panels, another option is to mount 2 - 3.5" round speakers where the factory 4x10 dash speakers already is.
If you don't want to alter the factory kick panels, just get a pair of repops. Cut a circle in it for the speakers. We did this a gazillion times back in the day. Pair of 6x9 Jensens on the rear shelf ( actually in my car today ).
Thank you
1. Made me look - I’m only seein A-body kick panels for speakers, not B-bodies
2. I’m adding A LOT of electrical stuff the “correct” way this year. I’m installing relays with direct battery power & tapping into (no wire cutting) the fuse block for a on/off signal
I did the second one, one relay to get power from the battery to a small aftermarket fuse block. Relay gets the switching signal from the stock fuse block. So far its overkill because I only added some analog gauges, but it gives me room if I add EFI or something down the road, and I set it up so its easily removable with no hackery to the car or stock wiring.
One Wheel Peel ,where on the factory fuse block did you get power ?
I found an enclosure for a retro looking stereo that has blue tooth . It looks like it belongs .
My feeling is the '66 made it almost 60 years without being cut up or modified ,who am I to change it ?
I'd like to hide the speakers as much as possible
I think it was the original radio circuit but I'm not sure. All I did was look behind the fuse box, I found a male spade connector behind one of the fuses and checked if it had power in key on or acc, it did, and used it. Its like they saw me coming 56 years ago.
If you want an underdash stereo system, is not anymore a “factory look” so your wish is indeed contradictory.
With ammeter, the battery source is not a correct place to get the power, but alt post or anywhere into the line between amm and alt post.
Thanks! Follow up question - I did a basic ammeter bypass years ago (100A in-line fuse from alternator I believe ?), so my ammeter doesn’t “really” work anymore. Should I still tap into the alternator???
Factory can be expensive, which is why I went period correct with an aftermarket FM/AM/CB from the 70s in the stock location.
Of course right after that I found an affordable factory AM radio :rolleyes:
Direct alternator to battery by-pass, or “shunt wire” by-pass? Better hope you never experience a short in any of the stock un-fused wiring, things will burn. By-passes the stock designed circuit protection (fusible link) as well.
I’m not sure. I’ll have to look. It’s been that way 10 yrs or more. Why is a “shunt”? (I’m not an electrical whiz)
A period correct similar to this?
Wouldn’t be bad, althought that’s more 80s than 60/70s LOL
Don’t worry I was joking, I got your idea.
IMHO, I’d preffer to keep the stock location with a vintage look stereo system than get it hanging out from somewhere. But at each own :thumbsup:
Nacho, I'm adding the parallel wiring from the alternator to a 50-amp circuit breaker, can I get power for aux circuit from this line?
All added circuits, accs, or whatever must be spliced into the alt side of the charging circuit while ammeter is still present and operative… no matter where into the line, but allways on that side of charging circuit. So… yes.
Taking power from ammeter stud is also valid as far the bulkhead is conveniently bypassed (or “paralleled”) with the correct wire thickness. Also terminals correctly clean and tight.
To tight any extra wire added into the ammeter stud, need to hold the bottom nut (retaining nut with cluster/isolation) with a wrench. The tightening on amm stud must be made nut against nut, because get tight just the top nut, could make to spin the stud, breaking isolation, loosing stud from shunt, bending the ammeter shunt inside etc…
Also a junction block can be used somewhere in the middle, but considering the main wire between alt and junction block is also upgraded to the full current requirements for all lines spliced into the junction block
If you drop your fuse block, there is usually a couple of spare fused lugs you can plug into to get power.
