Fender tag decoding
12:16 AM
Cass City Michigan
Looking to decode the fender tag on my 74 Plymouth Satellite Sebring, looked on Google and can't find any sites to accurately decode it.
Most online deciders, generally, suck to begin with especially for later years and newbies.
He simply saved time and frustration by asking here first.
The only one I've found that is free is one that has incomplete data and most of the options on my car aren't on there due to low production numbers in 74
To be honest I was just messing with you knowing that someone will jump in and do it, however almost all of the codes span many years meaning you don't need a specific 74 decoder for the vast majority of codes.
As an example E44 is a 318 and D34 is a std duty auto trans. These codes have been the same for a long time as has many of the others. Point being that you can effectively decode the tag without a "decoder" and I know that most if not all of the codes are on line.
Come on man. @Mopar_Junkie_74 somebody will jump in and help. A lot of people here enjoy the challenge.
WTF. I did help him. I told him they are all over the internet which they are. I gave him one to use that I found his codes in 5 minutes. Why dont you offer him some suggestions instead of hot air..
Bottom row:
E44: 318-2V
D34: TorqueFlite automatic transmission
R - Plymouth Satellite, Sebring ("B" body)
H - High (price class)
23 - 2 door hardtop
G - 318 1-2BBL 8 Cylinder "LA" engine
4 - 1974 (model year)
G - St. Louis, Missouri
Six digits sequence number
Have you found the broadcast sheet for your car?
Bottom row:
E44: 318-2V
23 - 2 door hardtop
No unfortunately I think it was removed long before i owned it, the original owner custom ordered it which is why it is so highly optioned
It did help for some of the codes, but for the couple of v codes and the JL6 code I couldn't find anything for them
Some of them I know off the top of my head.......H51 is air conditioning, U is USA spec, 28 is 28" radiator, P31 is power windows, and L31 is fender mounted turn signals. M21 and M26 will be fender and body moldings, V1W is a white viny top. The V5X will be a black body molding of some kind. JL6 is Aztec gold.....had to look that one up.
JL6: Aztec Gold Poly, but I need to verify
What is the J codes (2 digits) on the 4th line from the bottom?
Thank you very much the those v codes were very confusing, I was confused about the U and the 28 as well, the second to last row was pretty confusing tbh
Google it is like saying to someone don’t ask me for help. I would have helped if I had the knowledge but I don’t. I’ve seen plenty of tags decoded on here when someone asks for help. I’ve even had one decoded here I was interested in buying. Thanks @DeltaV for stepping up.
V1YWTrim Grade/Style/Color
V = V Class
1 = Cloth and Vinyl Bench
Y = Gold
000Upper Door Frame: Full Door Panel
723Date Built: 7 / 23 / 1974
163260Order Number: 163260
V1WRoof Type OR Color: Full Vinyl Top - White
UBuilt to Specifications for USA Order
B41Front Disc Brakes Some Yrs. Power
G54Left Hand Outside Mirror - Remote / Chrome
H51Single Air /w Heater
J253 Speed Variable Wipers
J52Inside Hood Release
L31Hood / Fender Mount Turn Signal
M21Roof Drip Rail Moldings
M26Wheel Lip Molding
P31Power Windows
R21Solid State AM / FM
V5XBlack - Mouldings - Protective Insert Body Side
July 23 is a pretty late built date
