Fender tag decoding
V1YWTrim Grade/Style/Color
V = V Class
1 = Cloth and Vinyl Bench
Y = Gold
000Upper Door Frame: Full Door Panel
723Date Built: 7 / 23 / 1974
163260Order Number: 163260
V1WRoof Type OR Color: Full Vinyl Top - White
UBuilt to Specifications for USA Order
B41Front Disc Brakes Some Yrs. Power
G54Left Hand Outside Mirror - Remote / Chrome
H51Single Air /w Heater
J253 Speed Variable Wipers
J52Inside Hood Release
L31Hood / Fender Mount Turn Signal
M21Roof Drip Rail Moldings
M26Wheel Lip Molding
P31Power Windows
R21Solid State AM / FM
V5XBlack - Mouldings - Protective Insert Body Side
July 23 is a pretty late built date
Yeah I do agree that it was built very late, but it was a special order so they probably just used left over parts to build it, what's interesting is that the car currently has power steering yet it isn't listed at all, i wonder if it was added later on
I've never seen power steering identified on a fender tag. Only on the Broadcast Sheet.
Ohhhh welp that is an unfortunate loss, looks to be factory tho so I'm inclined to think it is
I don't believe I've ever seen a '74 B body without power steering. Sales brochures might show it's standard.
July 23rd is the SCHEDULED date and, unlikely, the actual build date. Cars were built well before and after the scheduled date.
Check the driver's door for the door sticker that shows the actual assembly date.
Not all options are coded on a tag. Power steering would not be standard nor coded on the tag.
L31 was only available with the A01 light package, which would not be coded on its own. So we can document the car got A01.
It also appears your car has many of the components of the A08 Luxury Equipment package (see below). Do some more looking and see if you have the other components listed.
Ordered and Special Ordered are two different things. Sitting down and checking boxes on an order sheet, common at the time, is simply ordered.
Asking for something outside of the normal option or production protocol (a non standard paint or interior, fleet attachment brackets for things like 'cop cars' or taxis, a promo car, etc) is special ordered.
For 1974, a Special Order car built at the St. Louis plant will, most likely, have a letter at the beginning at the VON and carry a Y39 code on the tag. (see attached. 999 paint, V08 trim Waiver. J VON and Y39 code)
There is no coding on your tag that indicates Special Order. The 1***** VON would indicate a typical Ordered car.
Interesting, i actually didn't know that, thank you for all the help good sir!
I have the 74 sales brochures, I can post a picture tomorrow of standard and options from the brochure.
The reason I'd assumed it was special ordered was because of the options that are on it, like the sundance interior some of the options in the A08 Package without being coded for the A08 Package itself, I looked in the catalog and you couldn't order a car like mine in the Satellite Sebring trim, you'd have to go up to the Sebring Plus which is not what this is and shows no documentation of, also the fact the original owner worked for chrysler, I had thought with all the evidence and details that it was not a regular order that was allowed to go through at chrysler unless you had pull at the company and could order it how you wanted I probably am wrong on the majority of it but I am fascinated to learn this stuff regardless and increase my education on this topic
It simply appears to be a well optioned car and not special ordered or made with left over parts.
It's not the intent of the fender tag to list all options so not all option codes appear on the tag. Complete option documentation is found on items like the broadcast sheet, window sticker or other factory documents.
Sometimes we have to reverse engineer what the tag tells us. Such as L31 on the tag tells us your car got the A01light package. A lot of the items on the tag are in the A08 package. See if the rest of the components are on the car.
1) Look at the door sticker for the final assembly date.
2) Look for a broadcast sheet. The most typical locations are in the springs of the back seats or the bottom of the front seat. Try to search above the dash. You may find one taped above the glove compartment.
For more information on standard and optional items, look in the library at Hamtramck Historical. The 1970 Hamtramck Registry Library Page (1970 - 1974)
RH23:
Plymouth Belvedere,Satellite
High
2 Door Hardtop
G4G: 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL
1974
St. Louis, MO, USA
282056: Sequence number
E44: 318 cid 2 barrel V8 230hp
D34: Light Duty Automatic Transmission
JL6: Aztec Gold Metallic (Dodge) Exterior Color
V1YW: Cloth/Vinyl Bench Seat, Gold Color
000: Full Door Panels
723: Build Date: July 23
163260: Order number
V1W: Full Vinyl Top, White
U: USA Specifications
B41: Front Disc Brakes w/Standard 10in RR Drum
G54: Outside LH Remote Chrome Racing Mirror
H51: Air Conditioning with Heater
J25: 3 Speed Wipers
J52: Inside Hood Release
L31: Hood/Fender Mounted Turn Signals
M21: Roof Drip Rail Moldings
M26: Wheel Lip Moldings
P31: Power Windows
R21: AM/FM Radio (5 1/2 Watts)
V5X: Body Side Stripes, Black
28: 28" Radiator
END: End of Sales Codes
It sucks I don't have the broadcast sheet as it was removed before I owned the car
RH23:
High
2 Door Hardtop
1974
St. Louis, MO, USA
J25: 3 Speed Wipers
P31: Power Windows
28: 28" Radiator
That is amazing thank you sir!
