- 11:39 AM
- Jan 29, 2018
- Midland Ontario, Canada
Comprehension isn't your thing either I see...
Run from the new ones heres a link about them. A bit long but explains the issues. I usually have some if needed. Also you have the right ballast resistor with it?HI All
I thought I posted this awhile back but can't find it... any way I have another ignition control module going out.. I've been thru like 3 or 4 in the past 30,000 miles.. this one is only like 1 to 2 years old.. bought from Napa auto.. Is there a better one over a stock application .. its a 5 pin one. I'm getting frustrated at having them be so bad.. the wires are kind of tight maybe I need to replace the pig tail to get some relief on the wires??
thanks in advance
www.forabodiesonly.com
And piss poor case groundsI think alot of perfectly good ECUs are being damaged...& thrown out.....& not related to the country of origin. It is because of mismatched coils &/or bal resistors.
Totatly agreed.I think alot of perfectly good ECUs are being damaged...& thrown out.....& not related to the country of origin. It is because of mismatched coils &/or bal resistors.
HI,Totatly agreed.
I have posted many times, multiple ignition issues are a direct result
of a mismatch between the ECU, distributor, coil, ballast resistor.
The ignition system may work but certain crucial factors are missed
often resulting in a reliability issue and/or component failure.
Just my $0.02...![]()
Many years back Mopar in their performance manuals posted a recommended list of matching ignition components using the Blaster II coil.HI,
HHHMMM I did put in a blaster II coil, the rest is stock stuff? So could the Blaster II be causing the problem???Burning up the ICM
And, we finally get to the REAL nitty-gritty. And the main reasons why some, including myself, never in 50 years had a bad module. Oh... and by the way... I graduated Kindergarten with honors in Coloring.Totatly agreed.
An Accel Super Stock coil would be a closer choice.The Mopar ign coil has a nominal 1.5 ohm pri res. With the 0.5 ohm bal res in series with it, the static current is 6 amps through the ECU, assuming there is no current limiting device inside the ECU.
The Blaster coils have 0.7 ohm pri res. If used with the stock bal res, the ECU current increases to 10 amps.....
Perhaps you should consider going back to the "origional" points, coil and ballast resistor and quit shoveling money on what you have so much poor luck with your present system. WHY DID YOU CONVERT TO ELECTRONIC IGNITION IN THE FIRST PLACE.....a buddy, magazine article, cruise peer pressure, in search of 50+ hp...or ??? IMO....quite fiddle ******* around, put the points back, and enjoy your car...nothing beats a reliable car ...instead of trying to fix it all the time....especially when it breaks down on the road......just a thought......others will disagree.......
BOB RENTON
Yup..An Accel Super Stock coil would be a closer choice.
I can't comment on the newer produced coils but I have one from 1988.
See? THIS is helpful. Knowing this, it would explain why an ECU would crap out early… it is getting too much current, leading to eventual early failure.The Mopar ign coil has a nominal 1.5 ohm pri res. With the 0.5 ohm bal res in series with it, the static current is 6 amps through the ECU, assuming there is no current limiting device inside the ECU.
Keep in mind...See? THIS is helpful. Knowing this, it would explain why an ECU would crap out early… it is getting too much current, leading to eventual early failure.
