- 10:08 AM
- Feb 20, 2012
- New Hampster
Mine is a bit different.
nice set upWe have a working dash cluster. Just have call Dakota to see where the Speedo wires get connected and program it.
Yeah, I don't think the tack is in a convenient position when you are racing it...
Things have changed in the last 10 years. Mine was a plug and play, once you got the wires run down. Mine worked basically like Greg stated. You got this, looks great,!!
I thought that you'd most dread the lack of power windows.Out of everything I’ve done on this car, most of all, I was dreading wiring the MP harness and the Dakota dash wiring. The directions for both were not as clear as they could or should have been. That said, the MP harness only had 6 or 7 wires to connect & now that I’ve done it and understand it, my fears were unfounded. The Dakota dash’s wiring diagram was generic and I feel that they could have been more brand specific and whether you were using an old school V8 or a modern engine.
Now that I have all that behind me, I feel that I’ve gone over the hump and what’s left to finish up will be a piece of cake.
That is right where I mounted mine.
I hope that your windshield does NOT leak. Mine does. I thought it was my wiper pivot seals so I replaced them a couple weeks ago.
For the second time, water got through and got something wet and the dials on the gauges froze in place. I parked at a store and came out, they went to zero upon restart but then they slowly swung to the right, back to the left, to the right like slow moving windshield wipers.
In 2017 or 2018 I had this happen...I washed the car, saw water dripping inside then the gauges quit working. Later once they dried out, all was fine again. I pulled the windshield to learn that the guy that installed it used ZERO sealant. When I reinstalled the glass, I used this:
Afterwards, it seemed like it was okay. Obviously it isn't.
Mark, assuming that system still uses the tiny buttons to change settings be sure to mount them in a convenient location where you can push the buttons and see the changes simultaneously.
I hate those tiny buttons because they dig into my fingertips. I would find better buttons if I had to do it over.Thanks, I realized that this morning and have to remove the small box from where I mounted it.
.The #8609 is like what is used on windshields that have no gasket. It hardens to a point where future windshield replacement requires destroying the gasket since the goop hardens so much.Must've been the same guy that installed mine..
The guy I found that was able to fix it also used the 3M stuff. Gooped it in the windshield frame and all in the gasket groove and so far so good.
I have seen the light!
Leave your personal life out of it!I mounted it.
