Drill Press?
It would be nice to get the kind of insight DeltaV offered on the Kobalt, if anyone is familiar with the Bauer.
For only $230 more, there's this Central Machinery Press/Mill.
I don't think I need a mill, but I didn't think I needed a Dremel either.
It's a benchtop unit though.
I can stop by Harbor Freight tomorrow and see if they have any on display.
I've got a HF nearby, but the closest Bauer floor unit is at a HF a couple hours away.
Here's the only floor unit Harbor Freight has -
BAUER 17 in. Variable-Speed Drill Press with Light
Thoughts? I imagine tracking down parts for this in the future would be nigh impossible.
$500 is a lot more than I was looking to pay, but not more than I can afford. But, "once and done," don't want to deal with this again.
Used would be nice, but I don't think I've ever seen one come up in this area.
Checkout Northern Tool and Tractor Supply stores in your area; and they should have websites showing what they available.
My drill press. It's a bit on the old side.
I ran this Asquith radial arm drill press for years on the railroad. Two 600 volt motors (one was used to raise and lower the arm), two speed gearbox with a range of 31 to about 800 rpm., automatic feed, big pump for cutting fluid. It was built in England in 1942, very reliable. I could drill 1 inch holes in cast steel in no time flat, long spirals of cuttings piling up everywhere.
That is one thing I have never had at home is a drill press. I don't have the floor space. I have always managed with my vise and hand drill. However, whenever I need to do something above a hand drill. We have over 35+ CNC machines, dozens of Bridgeports, dozens of manual lathes, several drill presses and any other kind of equipment needed for any job. I just stay after work to do what I need. Then take it home.
Yeah, That old guy is one of the first cordless drills out there! You can take it anywhere and set it up.
They sure don't make em like they used to!
I have an older floor model craftsman.i use it all the time.
If you get one get a cross vice for it also
MSC tools has nice selections
The HF in my county has two display models and I looked them over this evening:
12" Bauer benchtop for $299.99
1) The vertical height adjustment gearing was somewhat sloppy.
2) the clamp-up to keep the table from rotating around the post was closed and tight, but the table still moved.
3) the table was sloppy up-and-down when I pushed up on it.
4) Maybe this benchtop unit wasn't properly assembled?
5) Seems to be a pretty solid unit other than what I mentioned above. However, $299.99 seems high to me. I would spend $499.99 on the unit below instead.
17" Bauer floor mount for $499.99
1) Everything that matters is metal and solid.
2) It seems stout and I didn't see anything that concerned me.
3) It is Made in China
4) I don't know about future availability of replacement parts.
5) The only plastic I found were 4 knobs and the switches.
Yes. The carriage thing, side to side and back to front, is a nice thing to have. Probably not part of the drill press.
On a related note, there are a lot of old drill presses for sale on Facebook around the country.
For example, this used Delta 17-900 for $400 is a little bit more than one hour away from me.
I bought a ENCO. mill drill many years ago when they were still in business. Drove to Atlanta GA. To pick it up. Best tool purchase I ever made. Super handy. My old drill press is collecting dust.
Get one if you can. You won't regret it.
I had a chance to buy an old clausing lathe and Bridgeport cheap when the company I was working for closed/relocated. I didn't have the room at the time, nor the 440 they were wired for.
Now that I have room.... they are years gone.
It's nice to have around... Mine's 220 3ph, I use a VFD... My big Lathe was wired for 440, I switched it to 220 3 ph & use a rotary phase convertor for it...
