Thanks for checking in Geoff. Coil is E-core. Just checked the voltage right at the connector on the module it is 14.3 volts while running higher RPMs.
Thinking this is not the issue now. So far 3 LX301 Std Ignition and one Napa TP45 modules have failed.
Edit: I have the 1-3-5 plug wires bundled together where they pass down between the PS pump and the head. Maybe there is some cross firing there causing the problem? I will fix this next.
