TKX 70 Charger
Was able to put in some more time in the garage today. Driveshaft is in. I went with a new tailshaft seal the original seal was a little damaged. Filled the trans (Included a picture of the funnel setup). I also went with a new steering wheel and horn setup, might stain the wheel a little darker not sure. Messed around with the brake switch and as kern Dog has already stated - the switch is a bitch to get to work with the new tandem clutch/brake pedal setup. After wasting, I do know an hour?, on the setup I remembered that the Wilwood master cylinder I have has a pressure switch to activate the brake lights. Got lucky there. Still trying to figure out a clutch safety switch. I have a Honda motorcycle brake switch that I think will work. Gonna mess with that tomorrow. Solid time in garage today (before my daughter and then my brother came over needing oil changes) 4 hours. Total running time 40 hours.
Spent a couple hours today wiring up the center console, dome light, and the power windows. The reverse lights and the clutch safety switch are installed. Tomorrow I am going to let the car down and fire it up! Test drive to follow. Hours today 5. Total running - 45 hours for the Tremec 5 speed conversion in a 1970 Charger 500 SE.
I'm curious about your clutch safety switch. How and where is it installed.
I used a door limit switch for a bus from work. Its a momentary on/off. It was at the bottom of the pedal so once the pedal was pushed all the way down the switch was closed. I have since eliminated the switch as you really had to push the pedal all the way to the floor. Became too glitchy for me. Right now I have a switch that is hidden that grounds the solenoid. Works as both a safety switch (if you remember to turn it off) and a anti- theft switch.
I have a Honda motorcycle brake switch that I am eventually going to attach to the clutch pedal but as of now I am the only one that drives the car so not high on the priority list.
Sorry for the lack of posting as I have been really busy. The conversion was completed the beginning of April. All said and done the man hours was 45. I have to say that if I was to do another one the time would be around 30 hours and if done by a shop that has experience with the b body conversion an appropriate time would be 20 -25 hours total.
Attended the first car show this year with the 5 speed TKX. As others have said - why did I wait so long? I absolutely love it. Only thing I would say is be careful if the roads are just a little wet. I went sideways through the first four gears and I am in the take it easy break-in period!
Thanks for taking the time to document your experience with this install process. I’m looking forward to doing this swap on my 72’ RR and any info that can be collected in advance is helpful.
I did something different.... No clutch switch, instead I used the neutral switch (on the tailshaft housing) on the trans, grounded one side & connected the other side to the starter relay... works perfectly...
Been a while since I have been able to post. Last week removed the break in fluid and added the synthetic fluid ( As already stated Tremec, should work on a better position for the fill what a PIA).
I have had a vibration after 55 - 60 mph.
I have just added a 2 deg shim to raise the pinion angle, based upon using Tremecs driveline operating angle app.. What a difference a few degrees make. Car now drives smooth at any speed, well haven't taken over 85 mph yet. Really smooth on hard acceleration. May think about raising the pinion another 1/2 or full degree (based on the smoothness of the heavy acceleration because the movement of the pinion angle up). Just a little bit of pistol grip shake above 60 mph.
Car show in Chesapeake City MD tomorrow. Must get a "Sorry car not for sale" placard as I am asked every time I come to stop.
