fontleyroy
Was able to put in some more time in the garage today. Driveshaft is in. I went with a new tailshaft seal the original seal was a little damaged. Filled the trans (Included a picture of the funnel setup). I also went with a new steering wheel and horn setup, might stain the wheel a little darker not sure. Messed around with the brake switch and as kern Dog has already stated - the switch is a bitch to get to work with the new tandem clutch/brake pedal setup. After wasting, I do know an hour?, on the setup I remembered that the Wilwood master cylinder I have has a pressure switch to activate the brake lights. Got lucky there. Still trying to figure out a clutch safety switch. I have a Honda motorcycle brake switch that I think will work. Gonna mess with that tomorrow. Solid time in garage today (before my daughter and then my brother came over needing oil changes) 4 hours. Total running time 40 hours.
