I hate plumbing
3sloppydogs
5:45 PM
carroll county MD.
Woke up this morning
Smiled with the rising sun
Went to put clothes in the wash
And there's a leak coming from the main feed line where it tees
I will repair it
But it's a PITA and I am not a fan of plumbing
Ok, that's my rant for the day
I will repair it
I feel your pain. Careful with that main
House main or washer main? Copper or PVC?
I've had excellent luck with the SharkBite connectors. All you need is clean cuts, and they will connect copper to copper, (C)PVC to (C)PVC, copper to CPVC, they even have PEX versions with the proper insert. MUCH easier than soldering with a torch , especially in tight spaces.
Look at the package, 1/2" pipe connectors will slip on 3/4"; 3/4" pipe connectors slip on 1". Pre mark your pipes to make sure you have full coupling, and they're a snap (literally) to work with. Hint: spend the 2.89 and buy the orange horseshoe release tool for the size pipe you're using. Trust me. You'll probably have to un-couple at least one connection before you fijish
On the apartment I'm redoing, I solder copper for anything "structural" - i.e. valves people could be turning, and the main feed into the unit (water main to shutoff valve; shutoff valve to hot/cold split; split to cold feed; split to water heater).
From there I just SharkBite convert to CPVC, and glue my way through the apartment.
Stub-ups through the floor to valves (sink, toilet) I go back to copper and clamp securely to a stud or joist for strength for when people have to mess with them and I always use metal valves, not plastic; the tub/shower manifold and piping is also copper for strength. I don't want plastic anywhere people are going to mess with it; it gets brittle over time and I'd rather have any torque loads go to copper that's securely mounted.
I like working on incoming plumbing a lot better than working on outgoing plumbing!
Had a leak in my kitchen wall last fall. Pinhole in a copper elbow (had to start low and work up till I found the leak)
I cut it out, got a SharkBite 90, cut the legs to fit, and used SharkBite connectors to put it all in so I didn't have to solder inside the wall
I actually enjoy plumbing as long as it's copper... something satisfying about a really nice solder joint. had to do my hot water tank last year and re-route some pipes... came out nice
I hate plumbing too. I can do it to some extent and do most of my own repairs, but I hate it. I don’t soldier pipe though.
I cheat on the water heaters - solder pipes to a SharkBite 18" flex hose, to the water heater, then another out to the plumbing.
But I am proud of my feed manifold (post 3 pic 1). Zero leaks, perfect fit, first time.
I like copper...but time and money and ease mean I glue plastic for most of the stuff because I can zip right through it.
Might be nuts but i trust solder joints... my house is 43 years old and not a single leak or corrosion (lucky) yet.... I'm sure sharkbites are great but.. just dunno.. seems wrong :)
Went thru the same debate. Tried one as a temp fix years ago...still solid and dry...so I'm no longer afraid of them. I use sparingly and prefer solder (copper) or glue (CPVC)...but for space constraints or material transitions, they're awesome.
That said, I try to make sure they're immobilized from both ends (like valves), because motion makes leaks.
You should see all the copper for our new boiler install years ago. It's a 4 zone system and it's all copper. I should be down polishing it right now. :rofl: :rofl:
You do that yourself? And there is something about when solder flows in soo perfect.. one of the most satisfying things to me.. but i'm easily pleased :) also looks like my same hot water tank... f'n $1500 due to the exhaust fan... just annoys me
Edited to fix a bad word... hate to offend 60 year old men that say it 50 times a day :)
You do that yourself? And there is something about when solder flows in soo perfect.. one of the most satisfying things to me.. but i'm easily pleased :) also looks like my same hot water tank... ******* $1500 due to the exhaust fan... just annoys me
Nope, hired it done. Made the call and wrote the check.
"Sweat" fittings are truly an art.
I can do it but I'm not crazy about it.
However, the bread trick is genius, whoever first thought of that.
I learned plumbing from my dad and father-in-law. As stated, I'll do plumbing anytime vs. sheetrock. I copper sweat everything like a champ.. But... our current water heater I used those sharkbite hoses... great !
i HATE drywall... well...i don't mind hanging it.. but i hate mudding/sanding.... same with bodywork. I like painting..i hate prep.
I think I know this about plumbing. They swear more than the other trades.. When I built my new house during COVID. I saved enough on the insulation, I paid the plumbers to crawl around in the crawl space. Inspector found a leak. White or black pipe I asked. What difference does it make they asked. I did the white pipe connections, plumber did the black. Was the plumbers leak not mine.
Just recently I may have found the answer as to why my pump saver clicks. Pressure issue with the tank and the main pressure. Hope it is fixed. Found info on line.
