fullmetaljacket
- 12:36 AM
- Oct 15, 2010
- Brooklyn, New York
Contrary to other makes and their drag links, the Mopar drag link at the points of mounting (Pitman arm, Idler arm, Tie rod ends) are considered a non wear item.
For that reason alone, is it NOT so important to lube those ends at the time of mounting? How many of you actually apply a dab of bearing grease, white lithium or just anti-seize in the mounting holes or do y'all just install dry?
